%OSAPI-4-TIME_SHIFT_DETECTED
Gaurav Singh
Hi All,
I am getting below error on 3850 SW. i am unable to understand this error, kindly suggest me for effect and resolution.
*osapiBsnTimer: STANDBY:2 wcm:  %OSAPI-4-TIME_SHIFT_DETECTED: Detected backward time shift. Last: 1444143429.950053. --> Now:1444143429.948961.
CITIX-CORE-SW# sh ver
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.02.03.SE RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 23-Sep-13 18:24 by prod_rel_team
Gaurav
Ganesh Hariharan
Hi All,
Gaurav
Hi Gaurav,
As per Cisco documentation , this is know bug id CSCud22987 which can be ignored.
​below is the details about the bug details
Symptom:
STANDBY wcm: %OSAPI-4-TIME_SHIFT_DETECTED: Detected backward time shift
message may be seen on a 3850
Conditions:
The message is seen on a switch running IOS-XE 3.2.0, 3.2.1 or 3.2.2
Workaround:
None. The message is cosmetic and may be ignored.
Hope It Helps..
-GI
Rate if it Helps..
7 Replies 7
Ganesh Hariharan
Hi All,
Gaurav
Hi Gaurav,
Symptom:
Conditions:
Workaround:
Hope It Helps..
-GI
Rate if it Helps..
Hi Ganesh,
Thanks for the time and information which you have shared with me.
Hi Ganesh,
Hi Gaurav,
No Problem, I Hope you have got your query clarified.
-GI
Please mark this thread as answered so that others can also be benefitted
Thank you
So,why does this happen ?
kimseng
Frequent Visitor
Frequent Visitor
How to solve this issue? my switch is cisco WS-C3650-24TD
Feb 8 11:23:25: *%TIMERLIB-4-TIME_SHIFT_DETECTED:Switch 1 R0/0: wcm: Detected forward time shift. Last: 1581135805.362578. --> Now:1581135805.586955.
I could not find anything, anywhere, about this particular message. Which IOS version are you running (Fuji-16.9.4 MD is recommended). Also, can you post the running configuration ?
