%OSPF-4-ERRRCV: Received invalid packet: mismatch area ID from x.x.x.x, VLANXX
mwood000111
Setting up a simulation in VIRL of our network.  Flow of traffic is below.  There is some hairpinning from core to ASA (inside) then ASA (WAN) back to core and to edge router out
Core-->ASA-->Core-->Edge router
We have a single ASA and are looking to add another pair and enable HA.
ASA has an OSPF adjacency to a C9300 Core 1 and a C9300 Core 2 (HSRP).  I have HA created between the FW pairs and once I failover, I see this message below on Core 1 and Core 2:
*Dec 28 18:17:42.658: %OSPF-4-ERRRCV: Received invalid packet: mismatched area ID from backbone area from x.x.x.x, Vlan51
Failover is successful and the standby becomes the primary but OSPF doesnt form and no routes are propagated on ASA.  I fail back over to primary and error is gone and OSPF forms.   Any thoughts?  Pertinent configs below:
Core 1
interface Vlan51
ip address 10.5.7.36 255.255.255.240
ip ospf lls disable
ip ospf 1 area 3
Core 2
interface Vlan51
ip address 10.5.7.37 255.255.255.240
ip ospf lls disable
ip ospf 1 area 3
ASA
router ospf 20
router-id 10.5.7.33
network 10.5.7.0 255.255.255.0 area 3
log-adj-changes
redistribute static subnets route-map FilterDMZ
default-information originate
Any assistance would be appreciated.  Thanks.
I am not sure if this is related at all, but I remember a quirk in VIRL where the MAC addresses on the firewall interfaces were the same by default, and you couldn't even connect two firewalls back to back without manually changing the MAC address on one interface...check if by any chance both your firewalls are using the same interfaces to connect, and if so, change the MAC address on one of them.
Hello
@mwood000111 wrote:
interface Vlan51
ASA
router ospf 20
Make sure the network statements are the correct on the ospf peerings so they are see as being in the same area
Kind Regards
Paul
