OSPF and HSRP
anitachoi3
Hi expert,
We would like to mix the OSPF and HSRP to provide a better service to custemers. The solution is following:
There are two uplink routers, R1 and R2. Each uplink router connects to one distribution layer router (R3 and R4). Below is the configuration for your reference.
Is it possible to build a "ospf nei" between two floating ip ONLY (192.168.1.1 and 192.168.1.4)? there is no "ospf nei" between the direct connection of each router. how to config it to achieve this approach?
There is only one FIB. If one of uplink routers is failure, the converging time should be very fast (depend on the HSRP). It would be less service impact on user. is it correct?
R1
interface GE 0/1
desc to R3 GE 0/1
ip address 192.168.1.2 255.255.255.248
standby 1 preempt
standby 1 ip 192.168.1.1
standby 1 priority 95
router ospf 20
network 172.16.1.0 0.0.0.255 area 0
R2
interface GE 0/1
desc to R4 GE 0/1
ip address 192.168.1.3 255.255.255.248
standby 1 preempt
standby 1 priority 105
router ospf 20
network 172.16.2.0 0.0.0.255 area 0
R3
interface GE 0/1
desc to R3 GE 0/1
ip address 192.168.1.5 255.255.255.248
standby 1 preempt
standby 1 ip 192.168.1.4
router ospf 20
network 172.16.3.0 0.0.0.255 area 0
R4
interface GE 0/1
desc to R4 GE 0/1
ip address 192.168.1.6 255.255.255.248
standby 1 preempt
router ospf 20
network 172.16.4.0 0.0.0.255 area 0
rdge
Anita
E31qinhaijun
hello
      You should announce 192.168.1.0 255.255.255.248 in every router
I try to add the ip segment (192.168.1.0/29), the client side router can establish two nei. In R3, there are two nei (R1 and R2). The opposit nei IP is 192.168.1.2 and 192.168.1.3. It cannot build nei between two floating IP addresses.
Any idea or advice?
Rdge
Anita
Giuseppe Larosa
Hello Anita,
I would recommend to try to use ways to improve OSPF convergence instead of adding HSRP to the picture.
There are two ways to do this:
a) use hold-timer 1 second and with sub-second hello timer, this uses the command hello-multiplier at interface level
see
http://www.cisco.com/en/US/docs/ios-xml/ios/iproute_ospf/command/ospf-a1.html#wp2917383021
b) use of IP fast convergence using BFD (Bidirectional Forwarding Detection), but this may be unsupported on your devices as the feature has been introduced in service provider environments.
http://www.cisco.com/en/US/docs/ios-xml/ios/iproute_bfd/configuration/15-mt/irb-bi-fwd-det.html
I agree with the other poster that your OSPF configuration doesn't look like complete, as in order to create OSPF adjacencies you need to add a network ... area 0 statement for the IP subnets between R1-R3 and R2-R4.
Hope to help
Giuseppe
Hi Giuseppe,
Yes, the option "a" would be one of solution to achieve the purpose.
Please see if there is any possible and feasible alternatives.
rdge
Anita
