OSPF area range command doesn't work
devyatkin
Community Member
Hello All,
I have three routers R1-R2-R3. R1-ASBR,Area600. R2-ABR,Area600,Area0,Area8(Totally NSSA). R3 - Area8.
I tried to summarize routes from Area8 with area 0 range 10.176.0.0 255.255.0.0 but it doesn't work. I can't see summary route on R1 and in R2 OSPF Database.
Also, I have output
R2#show ip ospf
Routing Process "ospf 1" with ID 10.159.210.0
    Area BACKBONE(0) (Inactive)
        Number of interfaces in this area is 1 (1 loopback)
        Area has no authentication
        SPF algorithm last executed 00:40:12.540 ago
        SPF algorithm executed 6 times
        Area ranges are
           10.176.0.0/16 Passive Advertise
        Number of LSA 5. Checksum Sum 0x035D1A
        Number of opaque link LSA 0. Checksum Sum 0x000000
        Number of DCbitless LSA 0
        Number of indication LSA 0
        Number of DoNotAge LSA 0
        Flood list length 0
    Area 8
        It is a NSSA area
        Perform type-7/type-5 LSA translation
    Area 600
Configuration of routers below:
R1
interface Loopback0
ip address 10.1.1.1 255.255.255.0
interface FastEthernet1/0
ip address 10.170.100.1 255.255.255.252
router ospf 1
summary-address 10.0.0.0 255.0.0.0
redistribute connected subnets
network 10.170.100.1 0.0.0.0 area 600
R2
interface Loopback0
ip address 10.159.210.0 255.255.255.255
ip address 10.170.100.2 255.255.255.252
interface FastEthernet1/1
ip address 10.159.176.1 255.255.255.252
router ospf 1
area 8 nssa no-summary
network 10.159.176.1 0.0.0.0 area 8
network 10.159.210.0 0.0.0.0 area 0
network 10.170.100.2 0.0.0.0 area 600
R3
interface Loopback100
ip address 10.176.254.1 255.255.255.255
ip address 10.159.176.2 255.255.255.252
router ospf 1
area 8 nssa
network 10.159.176.2 0.0.0.0 area 8
network 10.176.254.1 0.0.0.0 area 8
Could anyone say what is wrong?
Thanks!
Peter Paluch
If you want to summarize routes from area 8 then the area range command must refer to area 8, not to area 0. Replace the command with:
area 8 range 10.176.0.0 255.255.0.0
As a rule, the area range command always refers to the area that is being summarized (the source area), not the area into which the summary shall be advertised.
Best regards,
Peter
7 Replies 7
turnera
Level 6
Level 6
Try putting the word advertise after the area 0 range statement.
router ospf 1
area 0 range 10.176.0.0 255.255.0.0 advertise
There is probably something else missing but this is what I see so far.
Just have tried. No changes.
Do a "clear ip ospf proc" and let the tables repopulate.
Peter Paluch
Best regards,
Peter
Nice catch Peter. I looked right past that.
Here is link to a good video of OSPF Route Summarization. Hopefully this helps as well.
https://learningnetwork.cisco.com/docs/DOC-8553
Peter, thanks!
R2#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R2(config)#router ospf 1
R2(config-router)#area 8 range 10.176.0.0 255.255.0.0
OSPF: This range in different area 0
R2(config-router)#no  area 0 range 10.176.0.0 255.255.0.0
R2(config-router)#
R2(config-router)#do show ip ospf
Supports only single TOS(TOS0) routes
Supports opaque LSA
Supports Link-local Signaling (LLS)
Supports area transit capability
It is an area border and autonomous system boundary router
Redistributing External Routes from,
Initial SPF schedule delay 5000 msecs
Minimum hold time between two consecutive SPFs 10000 msecs
Maximum wait time between two consecutive SPFs 10000 msecs
Incremental-SPF disabled
Minimum LSA interval 5 secs
Minimum LSA arrival 1000 msecs
LSA group pacing timer 240 secs
Interface flood pacing timer 33 msecs
Retransmission pacing timer 66 msecs
Number of external LSA 1. Checksum Sum 0x02D2C0
Number of opaque AS LSA 0. Checksum Sum 0x000000
Number of DCbitless external and opaque AS LSA 0
Number of DoNotAge external and opaque AS LSA 0
Number of areas in this router is 3. 2 normal 0 stub 1 nssa
Number of areas transit capable is 0
External flood list length 0
        SPF algorithm last executed 00:00:51.840 ago
        SPF algorithm executed 4 times
        Area ranges are
        Number of LSA 5. Checksum Sum 0x036218
        Flood list length 0
    Area 8
        It is a NSSA area
        SPF algorithm last executed 00:00:54.532 ago
        SPF algorithm executed 5 times
        Area ranges are
           10.176.0.0/16 Active(2) Advertise
        Number of LSA 4. Checksum Sum 0x01ADB6
        Flood list length 0
    Area 600
        SPF algorithm last executed 00:01:00.648 ago
        Area ranges are
        Number of LSA 6. Checksum Sum 0x04AB97
        Flood list length 0
R2(config-router)#do show ip route
     10.0.0.0/8 is variably subnetted, 6 subnets, 4 masks
O E2    10.0.0.0/8 [110/20] via 10.170.100.1, 00:01:13, FastEthernet1/0
C       10.159.176.0/30 is directly connected, FastEthernet1/1
O       10.176.254.1/32 [110/2] via 10.159.176.2, 00:01:13, FastEthernet1/1
C       10.159.210.0/32 is directly connected, Loopback0
O       10.176.0.0/16 is a summary, 00:01:13, Null0
C       10.170.100.0/30 is directly connected, FastEthernet1/0
R2(config-router)#
R1#show ip route
     10.0.0.0/8 is variably subnetted, 6 subnets, 5 masks
C       10.1.1.0/24 is directly connected, Loopback0
O       10.0.0.0/8 is a summary, 00:06:32, Null0
O IA    10.159.176.0/30 [110/2] via 10.170.100.2, 00:05:58, FastEthernet1/0
O IA    10.159.210.0/32 [110/2] via 10.170.100.2, 00:05:58, FastEthernet1/0
O IA    10.176.0.0/16 [110/3] via 10.170.100.2, 00:00:04, FastEthernet1/0
R1#
You are very welcome!
Just for your information, if a virtual link has been configured and is active in a non-backbone area (i.e. this area is a transit area), then the backbone networks internal to area 0 will not be summarized when advertising them into this transit area. This is stated in RFC 2328, Section 12.4.3:
      If an area is capable of carrying transit traffic (i.e.,
      its TransitCapability is set to TRUE), routing
      information concerning backbone networks should not be
      condensed before being summarized into the area.  Nor
      should the advertisement of backbone networks into
      transit areas be suppressed.  In other words, the
      backbone's configured ranges should be ignored when
      originating summary-LSAs into transit areas.
Best regards,
Peter
