OSPF authentication
chinpohpang851
I'm not quite sure the diffferences of these 2 commands.
# ip ospf authentication  (on interface)
# area 1 authentication   ( on area)
5 Replies 5
Reza Sharifi
The first one turns on authenticatin for one an interface only and the second one for a whole area.
but i tried the second area command it saids..
Message digest authentication enabled
No key configured, using default key id 0
I'll still need to use #ip ospf authentication-key to create the key?
Just another question, Area 0 is regarded as Backbone area?
Yes, have a look at this example:
http://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/13697-25.html
Correct, area 0 is also called the backbone area.
Hello
Yes area 0 is regarded as the Backbone.
Ospf authentication  2 ways
Global  = plain text or MD5 (router mode )
Interface = plain text or MD5
Router mode - By default enabled on all ospf interfaces but no key string is defined on the interfaces unless you wish to apply one then a key string  needs to be applied at a per interface basis
router ospf 1
area X authentication  ( message-digest- MD5)
int x/x
ip ospf authentication-key xxx ( Plain authentication)
ip ospf message-digest-key 1 md5 xxx (MD5 authentication )
if you wish NOT to run ospf authentication on a interface
int x/x
ip ospf authentication null
Interface Mode - enabled directly under the interface for which authentication is required
int x/x
ip ospf authentication (message-digest)
sh ip ospf interface x/x | in authen
res
Paul
Kind Regards
Paul
Ganesh Hariharan
As stated by others ,  The area authentication command in the configuration enables authentication for all the interfaces of the router in a particular area. If you want to configure plain text authentication for an interface then use  ip ospf authentication.
And Yes area 0 is backbone are in OSPF domain / network.
Hope it Helps..
-GI
Rate if it Helps
