OSPF config standards for Nexus
Rahul Kulkarni
As we know Nexus supports multiple vrf under same ospf process , but there is also a way where we can create multiple ospf process per vrf.
which should be preferred and why ?
Also if anyone can highlight the role of ROUTER-ID with regards to this type of config , it will be great
Type 1
router ospf 100
vrf vrf_a
vrf vrf_b
Type 2
router ospf 100 vrf vrf_a
router ospf 200 vrf vrf_b
Ganesh Hariharan
Hello Rahul,
Normally if you ask me , I would always go and configure per VRF basis only.
For example :-
switch# configure terminal
switch(config)# vrf context NewVRF
switch(config)# router ospf 101
switch(config)# interface ethernet 1/2
switch(config-if)# no switchport
switch(config-if)# vrf member NewVRF
switch(config-if)# ip address 172.0.2.1/16
switch(config-if)# ip router ospf 101 area 0
switch(config)# copy running-config startup-config
Have a look in the below link for good explanation on Router ID.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/unicast/5_0_3_N1_1/Cisco_n5k_layer3_ucast_cfg_rel_503_N1_1/l3_overview.html#pgfId-1114154
Hope it Helps..
-GI
