Controller Cisco
Abdelkebir1
Community Member
hello all, I have a question, I have 2 controller primary and backup I create users in controller primary how can I synchronous users with backup controlle. what i want to do is when i create user in primary controller automatically created in controller 2 ( backup ). if you have any solution tell me. Cisco 2500 series wireless Controller
thank you
Ganesh Hariharan
I believe you are talking about cisco wireless lan controller, If yes then The WLC in the Standby state does not need to be configured independently as the entire configuration (Bulk Configuration while boot up and Incremental Configuration in runtime) will be synced from the Active WLC to the Standby WLC via a Redundant Port.
Hope it Helps..
-GI
what i want to do is when i create user in primary controller automatically created in controller 2 ( backup ). if you have any solution tell me.  cisco 2500 series wirelles Controller
