ospf default-information originate metric change when advertise to mikrotik
Reza Zand
I have cisco 7200 router and mikrotik and I configure ip routing ospf between them. I use these command to advertise default route to mikrotik
 default-information originate metric 50
but my mikrotik show this route in its routing table with metric 20:
0 ADo  dst-address=0.0.0.0/0 gateway=192.168.108.1 gateway-status=192.168.108.1 reachable via  ether1-UpLink-Main distance=110 scope=20 target-scope=10 ospf-metric=20 ospf-type=external-type-2
With default ospf advertise route with external type 2 that neighbor router don't change metric. but in these case mikrotik change metric from 50 to 20.
Rolf Fischer
Level 9
Level 9
could you verify that the sequence-numbers of the Type-5 LSA for the 0.0.0.0/0 prefix are the same on both routers?
Cisco 7200: show ip ospf database external 0.0.0.0
Mikrotik (http://wiki.mikrotik.com/wiki/Manual:OSPF_Case_Studies):
/routing ospf lsa> print
Rolf
