catalyst 2948g When telnet connection message "No memory for telnet process"
sunsteel7378
Good morning
I'm using a translator.
The same phenomenon appears in eight devices.
Is this a memory bug?
 show cdp neighbors detail
Port (Our Port): 2/49
Device-ID: JAB04250BSU(Paldal4)
Device Addresses:
  IP Address: 202.30.0.135
Holdtime: 172 sec
Capabilities: TRANSPARENT_BRIDGE SWITCH
Version:
  WS-C2948 Software, Version McpSW: 4.5(3.0) NmpSW: 4.5(3)
  Copyright (c) 1995-1999 by Cisco Systems, Inc.
Platform: WS-C2948
Port-ID (Port on Neighbors's Device): 2/49
VTP Management Domain: unknown
Native VLAN: unknown
Duplex: unknown
InayathUlla Sharieff
it depends on what sort of memory is using the pool of memory.
Now you have one option you can try to console and get the outputs of show proc mem sorted
if no console then only option to get back is to reload the box.
