OSPF - EIGRP redistribution question
mguzman4158
Hello all,
I have to entry points to our data center - mpls and b2b (backup).  I want the backup b2b to be automated and not manually if the mpls goes down.  Ingress from the b2b I have switch running ospf with the firewall and redistributing those routes in eigrp.  How can I make the routes coming from the b2b (osfp) less desirable then the mpls routes? The easiest way to do it...Any suggestions? Thanks,
cadet alain
What is the routing protocol used for the MPLS CE-PE
Regards.
Alain
BGP, but is being redistributed to EIGR into our core, and the same case for b2b, ospf redis to eigrp into the core.  That's why I need to make the b2b less desirable when the mpls link is up so I don't create asymetric routing. Thanks...
Just make the metric of OSPF redistributed routes higher than the one redistributed from BGP.
Regards.
Alain
