ospf forwarding address for external routes
Kashish_Patel
Level 2
Level 2
I read this in a document:
"When OSPF learns an external LSA, it makes sure that the forwarding address is known
through an OSPF intra-area or interarea route before it installs it into the routing table. If the
forwarding address is not known through an intra-area or interarea route, OSPF will not install
the route in the routing table."
I am trying to understand from where this requirement comes from? Why OSPF will not install the route in the routing table if the forwarding address is known via ospf external route?
Rolf Fischer
Level 9
Level 9
the originating router sets the FA to a non-zero IP-address only when certain conditions are met:
The interface pointing to the next-hop IP of the external route
  • has to be OSPF-enabled (non-passive)
AND
  • has to be a multiacces-interface (network type broadcast or non-broadcast)
So if there is no OSPF interal route to reach the FA on other routers, someting went wrong and it's safer not to install the route.
Link: Common Routing Problem with OSPF Forwarding Address
Rolf
