ospf network routing
suthomas1
Level 7
Level 7
I need to configure ospf on router with following interface
10.156.25.126 /25
will the output be
router ospf 1
network 10.198.55.0 0.0.0.127
Is this correct. Please help .
John Blakley
Not exactly. You can do it 1 of 2 ways:
On the interface:
int fa0/0
ip addr 10.156.25.126 255.255.255.128
ip ospf 1 area 0
Or under the process:
router ospf 1
network 10.156.25.0 0.0.0.127 area 0
HTH,
John
HTH, John *** Please rate all useful posts ***
John Blakley
On the interface:
int fa0/0
ip ospf 1 area 0
router ospf 1
HTH,
John
Alessio Andreoli
Level 11
Level 11
Correct IF you specify the area you want this interafce belong to:
router ospf 1
network 10.198.55.0 0.0.0.127 area area_id
Alessio
