OSPF Not load balancing
Brandon Baker
We currently have 3 ISPs, the third just being added last week, When I set it up under OSPF in our Core switch it will not load balance, Our current defrault route in the core is going to ISP2 and when I add our new connection in as a default route it stelas all of the traffic from from ISP2 instead of load balancing. Can anyone please assist?
All 3 have same Costs as well
Thank you for posting this output. Though I am afraid that it did not shed much light for me about the issue. So let me take a slightly different approach. Am I correct that before you added ip route 0.0.0.0 0.0.0.0 X.20.128.139 200 you had only this single static default route ip route 0.0.0.0 0.0.0.0 x.20.128.1 200 ? And that with this single static default route it was achieving load sharing/load balancing?
If that is the case then it suggests that the load sharing/load balancing was really being done on 128.1 and that perhaps we should be looking to this device to understand what causes the issue.
Rick
Rick
35 Replies 35
Richard Burts
There is not enough information here for us to know what is the cause or to be able to give you much assistance. For one thing we would need to know how each of the ISP is connected to you. And we would need to see details of how you have configured OSPF. And we would benefit from seeing the output of show ip ospf database to see how each ISP is advertising routes to you. From your description it seems that the new ISP is advertising a route to you with a metric better than the existing ISP. And if the metric is better then OSPF chooses the single best route and does not use both when one is better than the other.
Rick
Rick
Each ISP is connected through Fiber and BGP. ISP1 and ISP3 do have the same router-id as well.
ISP1 into asr1006
gigabitethernet from asr to catalyst 6509 in Vlan10
ISP2 into 7200VXR
gigabitethernet from vxr to catalyst 6509 in Vlan10
ISP3 into asr1006 (new connection)
gigabitethernet from asr to catalyst 6509 in Vlan3 (new connection)
core-6509#show ip ospf database
            OSPF Router with ID (X.X.128.22) (Process ID 1)
                Router Link States (Area 0.0.0.1)
Link ID         ADV Router      Age         Seq#       Checksum Link count
x.x.129.2    x.x.129.2    19          0x80005CBE 0x0001A0 6 (CMTS)
X.X.128.1    X.X.128.1    1954        0x80005010 0x005CA6 1 (ISP2)
X.X.128.21   X.X.128.21   708         0x80001016 0x00E220 1 (BACKUP CORE)
X.X.128.22   X.X.128.22   1461        0x80007525 0x00D4F6 4 (CORE)
X.X.128.253  X.X.128.253  1457        0x80000F0A 0x003B11 2 (ISP1 and ISP3)
                Net Link States (Area 0.0.0.1)
x.x.128.22   X.X.128.22   1461        0x800025AA 0x006F48
                Type-5 AS External Link States
Link ID         ADV Router      Age         Seq#       Checksum Tag
0.0.0.0         X.X.128.1    1954        0x8000096F 0x007953 1 (ISP2)
0.0.0.0         X.X.128.22   697         0x80000104 0x00C0FB 1 (CORE)
0.0.0.0         X.X.128.253  445         0x8000071E 0x0034EE 1 (ISP1 and ISP3)
*other routes directing to core*
Neighbor ID     Pri   State           Dead Time   Address         Interface
x.x.128.253    0   FULL/DROTHER    00:00:33    x.x.128.139  Vlan3 (ISP 3Orig.Pri 1 and BDR- I man. changed to Pri 0)
x.x.129.2      0   FULL/DROTHER    00:00:37    x.x.128.12   Vlan10 (CMTS)
x.x.128.1      1   FULL/DROTHER    00:00:31    x.x.128.1    Vlan10 (ISP2)
x.x.128.21     1   FULL/BDR        00:00:39    x.x.128.21   Vlan10 (BACKUP CORE)
x.x.128.253    1   FULL/DROTHER    00:00:32    x.x.128.2  Vlan10 (ISP1)
More info:
router ospf 1
log-adjacency-changes
redistribute connected
network x.x.128.0 0.0.0.127 area 0.0.0.1 (ISP1 and 2 fall under this category)
network x.x.128.136 0.0.0.7 area 0.0.0.1 (ISP3 falls under this)
maximum-paths 6 (just added this today but not help)
default-information originate always
Thanks for the additional information. Can you also post the output of show ip ospf database external?
Rick
Rick
Sure thing:
core-6509#show ip ospf database external
            OSPF Router with ID (x.x.128.22) (Process ID 1) (CORE)
LS age: 615
  Options: (No TOS-capability, DC)
  LS Type: AS External Link
  Link State ID: 0.0.0.0 (External Network Number )
  Advertising Router: X.X.128.1 (ISP2)
  LS Seq Number: 80000971
  Checksum: 0x7555
  Length: 36
  Network Mask: /0
        Metric Type: 2 (Larger than any link state path)
        TOS: 0
        Metric: 1
        Forward Address: 0.0.0.0
        External Route Tag: 1
LS age: 1348
  Advertising Router: X.X.128.22
  LS Seq Number: 80000105
  Checksum: 0xBEFC
  Length: 36
  Network Mask: /0
        TOS: 0
        Metric: 1
        Forward Address: X.X.128.1 (ISP2)
LS age: 1118
  Advertising Router: X.X.128.253 (ISP1 AND ISP3)
  LS Seq Number: 8000071F
  Checksum: 0x32EF
  Length: 36
  Network Mask: /0
        TOS: 0
        Metric: 1
*many more listed but assuming the default route is the only thing we are working with*
Thanks for the additional information. Based on what I thought I understood about the symptoms you describe I thought that there would be some difference in the external routes being advertised as default route (and you are right that while there may be many more external route entries it is the default entries that I wanted to see). But it looks like metric type and metric value are the same. So I am puzzled. Or maybe I do not have a correct understanding of what the issue is.
So perhaps you can provide some clarification about the problem? And perhaps it might help if you would post the output from show ip route (especially the default route parts) and perhaps some information about the configuration of the ASR1006 and the 7200 for OSPF?
Rick
Rick
Basically I had 1 gigabit ethernet connection coming from our VXR to the catalyst, 1 connection cominf from our asr to the catalyst and they were load sharing. I have since tried adding another connection from the asr to the catalyst and whenver I set the defualt route with the same metric as the connection going to the vxr it steals all of the traffic from that so I do not have any traffic coming into the catalyst through the VXR and it is all going through both ports of the ASR. (The ISP1 does not have a static route set up in the catalyst so I am unsure if this may be helpful information or not)
Gateway of last resort is X.X.128.1 to network 0.0.0.0
S*   0.0.0.0/0 [200/0] via x.x.128.1
               [200/0] via x.x.128.139
ASR:
router ospf 1
network X.X.128.0 0.0.0.127 area 0.0.0.1
network X.X.128.136 0.0.0.7 area 0.0.0.1
VXR:
router ospf 1
Does the VXR need to have the network info for the new connection?
In OSPF the network statement is used to determine which interfaces to include into the OSPF process. If the VXR does not have any interfaces in X.X.128.136 then there is no need to have that network statement.
Perhaps I am a little closer to understanding the issue. Am I correct in understanding that your catalyst has static default routes configured (and is using them rather than the advertised OSPF routes)? Would you post the static routes as they were configured with 2 and worked and how you configured the third route when you attempted to add it (and then all traffic went that way)?
Rick
Rick
B    X207.0/24 [200/3] via X.67.17, 12:37:44
B    X63.0/24 [200/5] via X.67.17, 5d21h
B    X46.0/24 [200/5] via X.67.17, 5d21h
B    X215.0/24 [200/5] via X.67.17, 5d21h
B    X21.0/24 [200/5] via X67.17, 5d21h
     X0.0/8 is variably subnetted, 11 subnets, 4 masks
B       X.47.0/24 [200/5] via X.67.17, 5d21h
B       X.41.0/24 [200/5] via X.67.17, 5d21h
B       X58.0/24 [200/5] via X.67.17, 5d21h
B       X.56.0/23 [200/5] via X.67.17, 5d21h
B       X56.0/21 [200/5] via X.67.17, 5d21h
B       X54.0/24 [200/6] via X67.17, 5d21h
B       X11.0/24 [200/3] via X67.17, 5d21h
B       X0.0/18 [200/2] via 66.X.17, 5d21h
B       X.26.0/24 [200/5] via X.67.17, 5d21h
B       X34.0/24 [200/3] via X.67.17, 05:18:09
B    X182.0/24 [200/5] via X.67.17, 5d21h
B    X.2.0/24 [200/3] via X67.17, 5d21h
C    X15.0/24 is directly connected, Vlan50
B       X228.0/22 [200/5] via X.67.17, 5d21h
B       X224.0/19 [200/2] via X67.17, 5d21h
B       X242.0/24 [200/7] via X67.17, 5d21h
C       X248.0/24 is directly connected, Vlan1
B       X0.0/23 [200/7] via X67.17, 5d21h
B       X.214.0/24 [200/3] via X.67.17, 5d21h
B       X109.0/24 [200/7] via X67.17, 5d21h
B       X240.0/23 [200/5] via X.67.17, 5d21h
B       X240.0/22 [200/5] via X.67.17, 5d21h
B       X93.0/24 [200/3] via X.67.17, 5d21h
B       X.43.0/24 [200/7] via X67.17, 5d21h
     X0.0/32 is subnetted, 2 subnets
S       X.132.194 is directly connected, Null0
S       X132.206 is directly connected, Null0
     X0.0/8 is variably subnetted, 4 subnets, 3 masks
B       X52.0/22 [200/3] via X67.17, 5d21h
B       X19.0/24 [200/3] via X67.17, 12:37:45
B       X18.0/24 [200/3] via X67.17, 12:37:45
B       X.76.0/23 [200/3] via X.67.17, 5d21h
B    X51.0/24 [200/5] via X67.17, 5d21h
B    X34.0/24 [200/5] via X67.17, 5d21h
B    X57.0/24 [200/5] via X67.17, 5d21h
     X0.0/8 is variably subnetted, 7 subnets, 4 masks
B       X.134.0/23 [200/5] via X67.17, 5d21h
S       X.67.105/32 [1/0] via X128.1
S       X67.17/32 [1/0] via X.128.1
B       X.94.0/24 [200/5] via X67.17, 5d21h
B       X.64.0/24 [200/5] via X.67.105, 5d21h
B       X64.0/19 [200/2] via X.67.105, 5d21h
B       X.75.0/24 [200/5] via X67.17, 5d21h
C    192.168.130.0/24 is directly connected, Vlan400
B    X94.0/24 [200/3] via X67.17, 5d21h
     X0.0/16 is variably subnetted, 15 subnets, 4 masks
C       X.140.0/24 is directly connected, Vlan420
C       X141.0/24 is directly connected, Vlan410
C       X142.0/24 is directly connected, Vlan36
C       X.143.0/24 is directly connected, Vlan39
C       X136.0/24 is directly connected, Vlan301
C       X.137.0/24 is directly connected, Vlan302
C       X.0/24 is directly connected, Vlan303
C       X139.0/24 is directly connected, Vlan304
C       X135.0/24 is directly connected, Vlan300
C       X128.0/24 is directly connected, Vlan20
C       X130.0/24 is directly connected, Vlan60
S       X131.0/24 [1/0] via X123.40
O E2    X129.2/32 [110/1] via X128.12, 03:43:14, Vlan10
O E2    X.0.0/18 [110/1] via X128.12, 03:43:14, Vlan10
B       X0.0/16 [200/0] via X.128.12, 5d21h
     X0.0/20 is subnetted, 1 subnets
B       X.128.0 [200/5] via X.67.17, 5d21h
     X0.0/8 is variably subnetted, 3 subnets, 3 masks
B       X.224.0/20 [200/3] via X.67.17, 5d21h
B       X.238.0/24 [200/3] via X.67.17, 5d21h
B       X.172.0/22 [200/3] via X67.17, 5d21h
C    X.131.0/24 is directly connected, Vlan401
B    X95.0/24 [200/3] via X.67.17, 5d21h
B    X.62.0/24 [200/5] via X.67.17, 5d21h
C    192.168.21.0/24 is directly connected, Vlan30
     X.0.0/8 is variably subnetted, 6 subnets, 3 masks
B       X.172.0/23 [200/3] via X.67.17, 4d10h
O       X.28.0/22 [110/2] via X.128.12, 03:43:16, Vlan10
O       X.24.0/22 [110/2] via X.128.12, 03:43:16, Vlan10
O       X.20.0/22 [110/2] via X128.12, 03:43:16, Vlan10
O       X.16.0/22 [110/2] via X128.12, 03:43:16, Vlan10
B       X.16.0/21 [200/0] via X128.1, 5d21h
C    192.168.20.0/24 is directly connected, Vlan25
B    X.22.0/24 [200/3] via X.67.17, 5d21h
     X.0.0/8 is variably subnetted, 6 subnets, 2 masks
O E2    X0.0/16 [110/1] via X128.12, 03:43:16, Vlan10
C       X.0.0/24 is directly connected, Vlan101
C       X0.0/16 is directly connected, Vlan102
C       X0.0/16 is directly connected, Vlan100
C       X.0.0/16 is directly connected, Vlan23
C       X.0.0/16 is directly connected, Vlan40
C    X6.0/24 is directly connected, Vlan2
     X0.0/32 is subnetted, 1 subnets
S       X.136.121 is directly connected, Null0
     X135.0/26 is subnetted, 2 subnets
C       X.135.64 is directly connected, Vlan37
C       X.135.0 is directly connected, Vlan35
     X.0.0/32 is subnetted, 1 subnets
S       X.4.32 is directly connected, Null0
C    X.129.0/24 is directly connected, Vlan7
B    X.43.0/24 [200/5] via X.67.17, 5d21h
     X.0.0/8 is variably subnetted, 15 subnets, 4 masks
O E2    X.102.0/24 [110/1] via X128.12, 03:43:17, Vlan10
S       X212.153/32 [1/0] via X128.2
S       X.51.97/32 [1/0] via X.128.2
O E2    X39.0/24 [110/1] via X128.12, 03:43:17, Vlan10
B       X33.0/24 [200/0] via X128.12, 5d21h
C       X.121.0/25 is directly connected, Vlan5
C       X123.0/24 is directly connected, Vlan13
B       X.197.0/24 [200/3] via X.67.17, 5d21h
B       X.208.0/21 [200/3] via X.67.17, 5d21h
B       X.211.0/24 [200/3] via X.67.17, 5d21h
B       X.25.0/24 [200/3] via X67.17, 5d21h
B       X39.128/25 [200/0] via X.128.12, 5d21h
O E2    X.33.128/25 [110/1] via X128.12, 03:43:17, Vlan10
B       X112.0/24 [200/3] via X.67.17, 5d21h
B       X225.0/24 [200/3] via X.67.17, 5d21h
B    X.119.0/24 [200/3] via X.67.17, 5d21h
     X0.0/8 is variably subnetted, 4 subnets, 2 masks
B       X12.0/22 [200/3] via X.67.17, 5d21h
B       X.214.0/23 [200/3] via X.67.17, 5d21h
B       X188.0/23 [200/3] via X67.17, 5d21h
B       X160.0/22 [200/3] via X67.17, 5d21h
     X128.0/24 is variably subnetted, 2 subnets, 2 masks
C       X128.0/25 is directly connected, Vlan10
C       X.128.136/29 is directly connected, Vlan3
B    X.42.0/24 [200/5] via X.67.17, 5d21h
     X131.0/24 is variably subnetted, 2 subnets, 2 masks
C       X.131.0/24 is directly connected, Vlan11
S       X.131.215/32 [1/0] via X.128.1
B    X18.0/24 [200/5] via X.67.17, 5d21h
S   0.0.0.0/0 [200/0] via X.128.1
O    X.140.0/22 [110/2] via X.12, 03:43:17, Vlan10
B    X.196.0/22 [200/5] via X.67.17, 05:18:08
B    X.162.0/23 [200/5] via X.67.17, 5d21h
O E2 X.136.0/22 [110/1] via X.12, 03:43:17, Vlan10
B    X.0.0/21 [200/5] via X.67.17, 5d21h
B    X12.0/22 [200/5] via X.67.17, 05:18:08
B    X.72.0/21 [200/5] via X.67.17, 05:18:08
B    X.144.0/20 [200/3] via X.67.17, 5d21h
B    X.60.0/23 [200/5] via X67.17, 5d21h
B    X.44.0/23 [200/5] via X.67.17, 5d21h
B    X128.0/20 [200/0] via X128.12, 5d21h
B    X.184.0/21 [200/5] via X.67.17, 5d21h
This is how everyhting is set up currently and load balancing between the 2 connections, the only difference that I make when I try to use the 3rd connection is this:
S*   0.0.0.0/0 [200/0] via X.128.1
               [200/0] via X.128.139
I hope this info helps
There is a lot of information here. I had not understood that there was also BGP  routing in your network but see a lot of what appear to be BGP learned routes. I do see some routes learned via OSPF. Would you do
show run | include ip route
on your catalyst and post the output?
And then give us the exact syntax that you used when you attempted to add the third default route?
Rick
Rick
core-6509#show run | include ip route
ip route x.90.212.153 255.255.255.255 x.20.128.2
ip route x.126.51.97 255.255.255.255 x.20.128.2
ip route x.118.67.17 255.255.255.255 x.20.128.1
ip route x.118.67.105 255.255.255.255 x.20.128.1
ip route x.47.136.121 255.255.255.255 Null0
ip route x.253.4.32 255.255.255.255 Null0
ip route x.16.131.0 255.255.255.0 x.20.123.40
ip route x.142.132.194 255.255.255.255 Null0
ip route x.142.132.206 255.255.255.255 Null0
ip route x.20.128.240 255.255.255.252 x.20.128.246
ip route x.20.128.248 255.255.255.252 x.20.128.254
ip route x.20.131.0 255.255.255.0 x.20.128.1
ip route x.20.131.215 255.255.255.255 x.20.128.1
I added this syntax to add the third route:
Thank you for posting what I requested. It does help me understand some parts but still leaves me puzzled about what is going on. Perhaps if you post the output of show ip protocol from the catalyst it might help explain some aspects.
What I see in the output that you posted is a single static default route which is configured with an administrative distance which is usually done to create a floating static route. I do not understand how this single static default route could have achieved load sharing (or load balancing - though this term is perhaps less technically accurate). And it looks like your attempt to add the other static default route did work. And I do not understand how the result of this would have been that all traffic used that route. I would have expected that some traffic would have used the next hop of 128.1 and that some traffic would have used the next hop of 128.139.
Rick
Rick
core-6509#show ip protocol
*** IP Routing is NSF aware ***
Routing Protocol is "ospf 1"
  Outgoing update filter list for all interfaces is not set
  Incoming update filter list for all interfaces is not set
  Router ID X.20.128.22
  It is an autonomous system boundary router
  Redistributing External Routes from,
    connected
  Number of areas in this router is 1. 1 normal 0 stub 0 nssa
  Maximum path: 6
  Routing for Networks:
    X.20.128.0 0.0.0.127 area 0.0.0.1
    X.20.128.136 0.0.0.7 area 0.0.0.1
  Routing Information Sources:
    Gateway         Distance      Last Update
    X.16.129.2         110      05:07:36
    X.20.128.1         110      6d00h
    X.20.128.2         110      13w3d
    X.20.128.253       110      4d07h
  Distance: (default is 110)
Routing Protocol is "bgp 40098"
  IGP synchronization is disabled
  Automatic route summarization is disabled
  Neighbor(s):
    Address          FiltIn FiltOut DistIn DistOut Weight RouteMap
    X.20.128.1
    X.20.128.2
  Maximum path: 1
    X.20.128.1         200      05:07:43
    X.20.128.2         200      1d05h
  Distance: external 20 internal 200 local 200
Rick
Rick
