OSPF NX-OS routed ports vs SVI problem
netspazz
I am having some issues trying to get OSPF working on a nexus 5K. I have simplified my configuration down to 2 switches/routers and just a couple interfaces to run some test. When I do this simple config using routed interfaces OSPF works and I can see each other as neighbors. When I switch over and use SVI then I don't see any neighbors on either switch. I can ping between switches/routers so I know the interfaces are up.
this is a really simple config and it does work when just using interfaces. is there something that must be setup with using vlan and SVI?
Below is a simple config, same on both sides, just one is using a different IP
vlan 100
interface Vlan 100
  no shutdown
  ip address 10.1.1.1/29                    <-- other side is using 10.1.1.2/29
  ip router ospf 100 area 0.0.0.0
interface Ethernet2/1
  switchport
  switchport access vlan 100
  no shutown
router ospf 100
  router-id 10.1.1.1
15 Replies 15
Reza Sharifi
Can you try and change the router-id to something different than the vlan svi IP. (a loopback address on each device)?
I created a loopback0 on each router and set them to 10.10.10.10 and 20.20.20.20. Set the router-id to those address and same result.
Below I have enclosed the output from one of the routers "sh ip ospf"
router3# sh ip ospf
 Routing Process 100 with ID 10.10.10.10 VRF default
 Routing Process Instance Number 1
 Stateful High Availability enabled
 Graceful-restart is configured
   Grace period: 60 state: Inactive
   Last graceful restart exit status: None
 Supports only single TOS(TOS0) routes
 Supports opaque LSA
 Administrative distance 110
 Reference Bandwidth is 40000 Mbps
 SPF throttling delay time of 200.000 msecs,
   SPF throttling hold time of 1000.000 msecs,
   SPF throttling maximum wait time of 5000.000 msecs
 LSA throttling start time of 0.000 msecs,
   LSA throttling hold interval of 5000.000 msecs,
   LSA throttling maximum wait time of 5000.000 msecs
 Minimum LSA arrival 1000.000 msec
 LSA group pacing timer 10 secs
 Maximum paths to destination 8
 Number of external LSAs 0, checksum sum 0
 Number of opaque AS LSAs 0, checksum sum 0
 Number of areas is 1, 1 normal, 0 stub, 0 nssa
 Number of active areas is 1, 1 normal, 0 stub, 0 nssa
 Install discard route for summarized external routes.
 Install discard route for summarized internal routes.
   Area BACKBONE(0.0.0.0) (Inactive)
        Area has existed for 04:31:33
        Interfaces in this area: 1 Active interfaces: 1
        Passive interfaces: 0  Loopback interfaces: 0
        No authentication available
        SPF calculation has run 2 times
         Last SPF ran for 0.000309s
        Area ranges are
        Number of LSAs: 1, checksum sum 0x953f
Is there any output when you issue "sh ip os nei" command?
no output from the comand:
router3# sh ip ospf neighbors
router3#
Andrea Testino
Hi there,
Just out of curiosity, are these vPC Nexus 5000s? If so, is VLAN 100 a vPC VLAN that you also have going across Eth2/1 to the other N5K?
Could you perhaps share the following with us from both N5Ks:
show vpc
show span vlan 100
show cdp neigh int e2/1
show run ospf show ip arp | i i 10.1.1. debug logfile OSPF_Adjacency debug ip ospf adjacency debug ip ospf events debug ip ospf hello debug ip ospf packets * Let this debug run for 1-2 minutes, then * show debug logfile OSPF_Adjacency > bootflash:support.txt * Attach support.txt to this thread *
Thanks!
- Andrea
- Andrea, CCIE #56739 R&S
No I am not using vPC.
Below is the output from the requested commands on both 5k's
I have attached the support.txt file
Thanks!!!!!
router3# sho vpc
% Invalid command at '^' marker.
router3# sh span vlan 100
VLAN0100
  Spanning tree enabled protocol rstp
  Root ID    Priority    32868
             Address     00b1.0123.472f
             Cost        4
             Port        257 (Ethernet2/1)
             Hello Time  2  sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32868  (priority 32768 sys-id-ext 100)
             Address     00b1.01b7.c12f
Interface        Role Sts Cost      Prio.Nbr Type
Eth2/1           Root FWD 4         128.257  P2p
router3# sh cdp neighbors int e2/1
Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater,
                  V - VoIP-Phone, D - Remotely-Managed-Device,
                  s - Supports-STP-Dispute
Device-ID          Local Intrfce  Hldtme Capability  Platform      Port ID
router4(TB01234700B)
                    Eth2/1         120    R S I s   N7K-C7018     Eth2/1
Total entries displayed: 1
router3# sh run ospf
!Command: show running-config ospf
!Time: Thu Feb 22 22:36:21 2018
version 7.3(0)D1(1)
feature ospf
router ospf 100
  router-id 10.10.10.10
interface Vlan100
router3# sh ip arp | i i 10.1.1.
10.1.1.2        00:15:18  00b1.0123.472f  Vlan100
router3#
2nd router
router4# sh vpc
router4# sh span vlan 100
VLAN0100
             This bridge is the root
Eth2/1           Desg FWD 4         128.257  P2p
router4# sh cdp neighbors int e2/1
router3(TB01B7C100B)
                    Eth2/1         146    R S I s   N7K-C7018     Eth2/1
router4# sh run ospf
!Time: Thu Feb 22 22:44:04 2018
version 7.3(0)D1(1)
feature ospf
router ospf 100
  router-id 20.20.20.20
interface Vlan100
router4# sh ip arp | i i 10.1.1.
10.1.1.1        00:03:46  00b1.01b7.c12f  Vlan100
router4#
I tried to reconfigure and see if I'm missing something but still running into a wall. This has to be some simple config I'm missing.
when I run "debug ip ospf hello" I see both routers sending out hello's but not receiving any.
first router:
2018 Mar  4 19:49:19.690421 ospf: 100 [10123] (default)  LAN hello out, ivl 10/40, options 0x02, mask /24, prio 1, dr 10.10.10.1, bdr 0.0.0.0 nbrs 0 on Vlan10 (area 0.0.0.0)
Second router:
2018 Mar  4 19:49:36.900383 ospf: 100 [10168] (default)  LAN hello out, ivl 10/40, options 0x02, mask /24, prio 1, dr 10.10.10.2, bdr 0.0.0.0 nbrs 0 on Vlan10 (area 0.0.0.0)
Any ideas on where to look at next?
Doing some more troubleshooting I may have found the issue, it has to do with multicast. Each router can ping each other, but I cannot ping 224.0.0.5 and I get the following error:
R1# ping 224.0.0.5
ping: either multicast replicate flag or source interface needs to be specified
i enabled the pim feature but still the same.
What is the difference between ospf using routing interfaces versus vlan interfaces? i ask this since just using plain routing interfaces everything works fine. I'm not experienced with PIM on nx-os.
Any ideas?
Can you try by making link between 2 switches as trunk instead of access link?
Thx
MS
ok, I set the vlan interface tp a trunk. I can ping from router to router but still no ospf neighbors are showing up.
thanks,
Not the vla interface but the directly connected i/f (on both sides)
  switchport
  switchport access vlan 100  --> try by set it to trunk port.
  no shutdown
Thx,
MS
yes, sorry I described it wrong. below is what i have configured:
interface Vlan10
  no shutdown
  ip address 10.10.10.1/24
  ip pim sparse-mode
  switchport
  switchport mode trunk
  switchport trunk allowed vlan 10
  no shutdown
You definitely do not need any multicast configuration to stand this up. 224.0.0.5 is a well-known multicast group and the router knows how to handle that traffic without the need for PIM.
If you have 30 minutes sometime this week, Id be happy to take a look at your setup. This should be fairly straight forward and should work with minimal configuration.
Example in my two Nexus 5600s using SVIs to pair across an L2 trunk:
LEAF-30# sh run int po4096
!Command: show running-config interface port-channel4096
!Time: Mon Mar  5 18:39:53 2018
version 7.1(5)N1(1)
  speed 10000
LEAF-40# sh run int po4096
!Time: Mon Mar  5 18:36:30 2018
version 7.1(5)N1(1)
  speed 10000
LEAF-30# sh run int vlan 20
!Command: show running-config interface Vlan20
!Time: Mon Mar  5 18:40:09 2018
version 7.1(5)N1(1)
interface Vlan20
  no shutdown
  no ip redirects
  ip address 192.168.20.4/24
  ip router ospf TAC-TES area 0.0.0.0
  hsrp version 2
  hsrp 20
    ip 192.168.20.1
LEAF-40# sh run int vlan 20
!Time: Mon Mar  5 18:36:46 2018
version 7.1(5)N1(1)
interface Vlan20
  no shutdown
  no ip redirects
  ip address 192.168.20.5/24
  hsrp version 2
  hsrp 20
    ip 192.168.20.1
LEAF-30# sh span int po4096 | i i vlan0020
VLAN0020         Root FWD 1         128.8191 P2p
LEAF-40# sh span int po4096 | i i vlan0020
VLAN0020         Desg FWD 1         128.8191 P2p
LEAF-30# sh ip ospf neigh
 OSPF Process ID TAC-TES VRF default
 Total number of neighbors: 1
 Neighbor ID     Pri State            Up Time  Address         Interface
 192.168.21.5      1 FULL/DR          00:02:07 192.168.20.5    Vlan20
LEAF-40# sh ip ospf neigh
 192.168.21.4      1 FULL/BDR         00:02:07 192.168.20.4    Vlan20
 LEAF-30# sh run ospf
!Time: Mon Mar  5 18:41:18 2018
version 7.1(5)N1(1)
feature ospf
router ospf TAC-TES
  redistribute static route-map STATIC_To_OSPF_Map
interface Vlan20
LEAF-40# sh run ospf
!Time: Mon Mar  5 18:37:55 2018
version 7.1(5)N1(1)
feature ospf
router ospf TAC-TES
interface Vlan20
LEAF-30# sh ip ospf int bri
 Total number of interface: 1
 Interface               ID     Area            Cost   State    Neighbors Status
 Vlan20                  1      0.0.0.0         40     BDR      1         up
 LEAF-40# sh ip ospf int bri
 Vlan20                  1      0.0.0.0         40     DR       1         up
Hello!
I have the same problem. Have you found any solution? If I configure port without vlan it's working.
