Showing results forĀ
Search instead forĀ
Did you mean:Ā
OSPF packet
Arjun Dabol
Level 3
Level 3
Can someone explain me in simple networking terms ...where does OSPF packet fits in a typical IP packet ?
and since 'OSPF LSA' carries prefix and other info..where does that fit in over all IP Packet concept ?
Is there any encapsulation happening here?
2 Accepted Solutions
Joseph W. Doherty
As also noted by Jon, it's the payload of an IP packet, specifically of a OSPF protocol IP packet.
It doesn't, beyond being one of the defined IP packet protocol types.
I.e. IP, itself, just tells us such a packet is one used by OSPF, it's then up to OSPF to make meaning of the IP packet's payload.
Rolf Fischer
Level 11
Level 11
This is a very good question!
When designing a large OSPF network, it can be challenging to decide how many routers you want to put in a single OSPF area.
I heard a very interesting advice in a CiscoLive session:
BRKRST-2337 - OSPF Deployment in Modern Networks (at ~17:30 minutes)
"Keep router LSAs under MTU size - avoid IP fragmentation."
Although IP fragmentation would (of course) work with very large OSPF Router-LSAs, you should avoid it. In simple terms, Router-LSAs carry the link-information of all the router-interfaces in an area (the details are quite complicated). A typical IP-packet sent over Ethernet with 1500 byte MTU would be able to encapsulate a OSPF Router-LSA that describes 119 links without the need for fragmentation. Depending on the type of connections this would typically correspond to ~50 routers.
Rolf
[EDIT]:
In order to produce a wireshark capture of fragmented OSPF packets I set up a quick lab with a large number of OSPF-enabled loopback interfaces (see attached file).
R1#show ip ospf database
                Router Link States (Area 0)
Link ID         ADV Router      Age         Seq#       Checksum Link count
1.1.1.1         1.1.1.1         347         0x80000010 0x0025B4 120
2.2.2.2         2.2.2.2         515         0x80000002 0x003BF8 1
                Net Link States (Area 0)
192.168.12.1    1.1.1.1         514         0x80000001 0x00C7EB
For the sake of completeness I want to point out that we're talking about ~50 (up to 118) neighbor-routers, since every router generates a Router-LSA only for its own interfaces in that area. So this is not really the maximum number of routers in an area - its rather the maximum number of neighbors in the same area...
Jon Marshall
There are different types of OSPF packet but put simply they are just like any other IP packet in the sense there is a L2 header, then a L3 IP header, then a payload and then a trailer.
The protocol field in the IP header is 89 which is for OSPF and then the payload is the OSPF packet.
Jon
vlopesba
Frequent Visitor
Frequent Visitor
What Jon told is pretty much truth
Just completing: although generally reffer TCP/IP refering to networks this is not really accurate. In OSPF case for example, it is not TCP/IP packet because OSPF doesn't rely on TCP for its connections: OSPF takes care of transport itself (and thus the IP protocol number).
If you compare a OSPF packet to Telnet, TFTP, HTTP or even BGP this diference is more clear: while OSPF header is seen right after Network Header, Telnet/TFTP/BGP/HTTP will have a TCP or UDP header (transport) prior to the protocol payload itself
OSPF and EIGRP are considered to be Network Layer protocol although there are some arguments that they have L7 functionalities. BGP and RIP for example do basically the same thing (distribute routing information), but are considered Aplication Layer protocols, maybe because they rely on transport protocol (TCP) for its connections. Classifying routing protocols in OSI/TCP models is pretty difficult and polemic though....
Anyway, I am adding a caputre with OSPF hellos and update (no transport protocol), LDP packets (UDP as tansport transport) and Telnet (TCP as transport protocol) packets. You can look at it with Wireshark and hope it can help you to clarify your doubt
Joseph W. Doherty
Rolf Fischer
Level 11
Level 11
Rolf
[EDIT]:
