OSPF redistribution into EIGRP
pfrancis3
Level 2
Level 2
Hello, I have router 5 and router 7 as OSPF neighbours connected via area 24.
Router 5 is running EIGRP and OSPF. Router 7 is only running OSPF. I am trying to redistribute the OSPF route 172.16.100.0/25 from router 7 into router 5's EIGRP instance.
However, I cannot seem to redistribute that network into Router 5.
Can someone please take a quick look at the configs below. I am sure it is something simple.
Thank you kindly for any help.
ROUTER 5 (EIGRP and OSPF)
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1524HT0O
spanning-tree mode pvst
interface GigabitEthernet0/0
 ip address 192.168.3.1 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 duplex auto
 speed auto
interface GigabitEthernet0/2
 ip address 192.168.2.1 255.255.255.0
 duplex auto
 speed auto
interface Vlan1
 no ip address
 shutdown
router eigrp 100
 redistribute ospf 1 metric 1000000 10 255 1 1500
 network 192.168.2.0
 network 192.168.1.0
 auto-summary
router ospf 1
 log-adjacency-changes
 redistribute eigrp 100 metric-type 1 subnets
 network 192.168.3.0 0.0.0.255 area 24
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
 login
end
ROUTER 7 (only OSPF)
hostname Router
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1524D5LZ
 ip address 192.168.3.2 255.255.255.0
 duplex auto
 speed auto
 ip address 172.16.100.1 255.255.255.0
 duplex auto
 speed auto
 ip address 192.168.4.2 255.255.255.0
 duplex auto
 speed auto
interface Vlan1
 no ip address
 shutdown
router ospf 1
 network 172.16.100.0 0.0.0.255 area 44
 network 192.168.4.0 0.0.0.255 area 34
ip classless
line con 0
line aux 0
line vty 0 4
 login
end
Are you trying to connect 2 areas together without area 0?
change "network 172.16.100.0 0.0.0.255 area 44" to network 172.16.100.0 0.0.0.255 area 24
and test again
5 Replies 5
Reza Sharifi
Can you post the output of "sh ip route" from both routers?
Is OSPF peering up between the 2 routers?
sh ip os nei
here is show ip route from router 5:
" 192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, GigabitEthernet0/1
L 192.168.1.1/32 is directly connected, GigabitEthernet0/1
192.168.2.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.2.0/24 is directly connected, GigabitEthernet0/2
L 192.168.2.1/32 is directly connected, GigabitEthernet0/2
192.168.3.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.3.0/24 is directly connected, GigabitEthernet0/0
L 192.168.3.1/32 is directly connected, GigabitEthernet0/0
D EX 192.168.4.0/24 [105/5376] via 192.168.2.2, 01:26:47, GigabitEthernet0/2"
Here is show ip route from router 7:
172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.16.100.0/24 is directly connected, GigabitEthernet0/1
L 172.16.100.1/32 is directly connected, GigabitEthernet0/1
O E1 192.168.1.0/24 [110/21] via 192.168.3.1, 01:43:21, GigabitEthernet0/0
[110/21] via 192.168.4.1, 01:41:43, GigabitEthernet0/2
O E1 192.168.2.0/24 [110/21] via 192.168.3.1, 01:43:21, GigabitEthernet0/0
L 192.168.3.2/32 is directly connected, GigabitEthernet0/0
192.168.4.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.4.0/24 is directly connected, GigabitEthernet0/2
L 192.168.4.2/32 is directly connected, GigabitEthernet0/2
Yes, neighbor relationships seem good.
show ip ospf neighbor from Router 5:
Neighbor ID Pri State Dead Time Address Interface
172.16.100.1 1 FULL/BDR 00:00:38 192.168.3.2
show ip ospf neighbor from router 7:
172.16.100.2 1 FULL/DR 00:00:35 172.16.100.2 GigabitEthernet0/1
192.168.3.1 1 FULL/DR 00:00:34 192.168.3.1 GigabitEthernet0/0
192.168.4.1 1 FULL/DR 00:00:39 192.168.4.1 GigabitEthernet0/2
and test again
Leonir Hoxha
You are running multi-area OSPF without a backbone area (area 0), which from design point of view will not work.
The reason why on R5 routing table you see only 192.168.3.0 (area 24) prefix and not  172.16.100.0 or 192.168.4.0 is because the last two prefixes are part of OSPF area 44 and 34 (on R7), and as I said earlier by design the prefixes from area 44 and 34 will not make it to area 24 (the Point-2-Point between R7 and R5), so in this case the ABR (R7) will not be able to forward LSA type-3 (inter-area routes) to area 24.
You need to introduce a backbone area or run the same area number on all interfaces respectively on R7.
