OSPF redistribution with single internal IP subnet with two different GW IP
MAKhan
need to understand if one /28 IP subnet can be redistributed through two different OSPF areas? for example:
GEO Location-1
ring having primary Ethernet IP address 10.10.1.1 and GW IP address 10.10.1.254 with internal ring IP subnet 10.10.3.1 - 10.10.3.14 /28 with OSPF area 101
GEO Location-2
same ring having secondary Ethernet IP 10.10.2.1 and GW IP address 10.10.2.254 with same internal ring IP subnet 10.10.3.1 - 10.10.3.14 /28 with OSPF area 201
thank you and best regards
Asghar
2 Accepted Solutions
Philip D'Ath
I don't see why not.
Hello
If i understand you correctly then NO you wont be able to, as both areas will try to advertise the same subnet and as such either area wont have visibility to the other for that /28 subnet or if you try changing metric types then one area are may have visibility to the other but than wont have access to its own /28
Lasty if the goal it to not advertise the same /28 to the other areas then its possible to do , But then you could open up yourself to potential route leaking and as such could result in the above.
res
Paul
Kind Regards
Paul
Philip D'Ath
Hello
res
Paul
Kind Regards
Paul
