OSPF, Rip, VPN, IPSec, and AVAYA VoIP with DHCP. How can I get the IP phones working on the second site?
I have an issue with my current project.  I am configuring a second site to use our current Avaya VoIP system in our head office and I am having trouble sending the DHCP and CallManger(H.323)  information over the VPN.
Our phone system is managed by Avaya Controller IPOffice (DHCP Server) and it isn't connected to our data network.
They sites are connected via IPsec VPN with OSPF areas and RIP v2. Redirected.
I have tried different option, but I am looking what is the best option to use that is stable and manageable.
If anyone has any ideas, please let me know.
Thanks.
Sam
5 Replies 5
Sam, what are the two devices running the VPN ? Can you post the configs ?
They are 2911 running the VPN.
where are your voice clients ? On interface GigabitEthernet0/2.113 (description Vlan113 b) ?
The access list that allows both DHCP and H.323 traffic would look like this:
(config)#ip access-list extended ALLOW_DHCP_H323
(config-ext-nacl)#permit udp any any eq 67
(config-ext-nacl)#permit udp any any eq 68
(config-ext-nacl)#permit tcp any any eq 1720
HI Georg,
The IPsec doesn't support multicast. I need to use GRE Tunnel over PPTP Site-To-Site VPN with Bridge protocol.
I have no idea how to configure it all.
Any suggestion.
Also, I would like to start with two new 2911 router with no configuration.
My site 1 location has the Avaya IPoffice and is the only one in the company.
This is my Site 1 config.
version 15.0
ip dhcp excluded-address 160.16.16.1 160.16.16.149
ip dhcp excluded-address 160.16.16.200 160.16.16.254
ip dhcp excluded-address 160.16.18.1 160.16.18.10
ip dhcp excluded-address 160.16.17.1 160.16.17.10
ip dhcp excluded-address 160.16.20.1 160.16.20.10
ip dhcp pool xyz
import all
network 160.16.16.0 255.255.255.0
dns-server 67.69.184.199 67.69.184.7 160.16.16.11 160.16.16.12
default-router 160.16.16.1
domain-name bfg.ca
ip dhcp pool VLAN111-Corp-Wifi
import all
network 160.16.18.0 255.255.255.0
default-router 160.16.18.1
domain-name xxxx
ip dhcp pool VLAN113-Guest
import all
network 160.16.20.0 255.255.255.0
default-router 160.16.20.1
domain-name xxxxx
ip dhcp pool VLAN110-Office
import all
network 160.16.17.0 255.255.255.0
dns-server 160.16.16.1 67.69.184.199 67.69.184.7 160.16.16.11 160.16.16.12
default-router 160.16.17.1
domain-name xxxx
ip name-server 67.69.184.199
ip name-server 67.69.184.7
ip name-server 8.8.8.8
ip name-server 160.16.16.1
crypto pki trustpoint TP-self-signed-1928327714
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1928327714
revocation-check none
rsakeypair TP-self-signed-1928327714
redundancy
policy-map VPO
class class-default
shape average 200000000
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key yyyyy address 10.10.10.12 255.255.255.224
crypto isakmp key yyyyy address 10.10.10.13 255.255.255.224
crypto isakmp keepalive 10
crypto ipsec transform-set Router-IPSEC esp-3des esp-sha-hmac
crypto ipsec profile VTI
set transform-set Router-IPSEC
interface Loopback0
ip address 11.1.1.1 255.255.255.0
interface Tunnel0
ip address 200.200.200.1 255.255.255.0
tunnel source 10.10.10.10
tunnel mode ipsec ipv4
tunnel destination 10.10.10.12
tunnel protection ipsec profile VTI
service-policy output VPO
interface Tunnel1
ip address 200.200.100.1 255.255.255.0
tunnel destination 10.10.10.13
interface GigabitEthernet0/0
ip address 10.10.10.10 255.255.255.224
ip nbar protocol-discovery
ip flow ingress
ip nat outside
ip virtual-reassembly
duplex auto
speed 100
interface GigabitEthernet0/1
no ip address
ip flow ingress
ip nat inside
duplex auto
speed auto
no ip address
ip flow ingress
ip nat inside
duplex auto
speed auto
encapsulation dot1Q 1 native
ip address 160.16.16.1 255.255.255.0
ip access-group LAN-VLAN1-IN in
ip flow ingress
ip nat inside
interface GigabitEthernet0/2.110
description Vlan110 b
encapsulation dot1Q 110
ip address 160.16.17.1 255.255.255.0
ip access-group LAN-OFFICE-IN in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
interface GigabitEthernet0/2.111
description Vlan111 b
encapsulation dot1Q 111
ip address 160.16.18.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
encapsulation dot1Q 113
ip address 160.16.20.1 255.255.255.0
ip access-group WLAN-Guest-In in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
interface GigabitEthernet0/2.500
encapsulation dot1Q 500
ip address 160.16.50.1 255.255.255.0
no ip redirects
ip flow ingress
ip nat inside
interface Async0/0/0
no ip address
encapsulation slip
router ospf 1
log-adjacency-changes
redistribute rip metric 50 subnets
network 160.16.16.0 0.0.0.255 area 0
network 192.168.0.0 0.0.255.255 area 1
network 200.200.100.0 0.0.0.255 area 0
network 200.200.200.0 0.0.0.255 area 1
router rip
version 2
network 192.168.1.0
ip forward-protocol nd
no ip http server
ip http port 8125
ip http secure-server
ip http secure-port 44554
ip dns server
ip nat inside source list NAT_ACL interface GigabitEthernet0/0 overload
ip nat inside source route-map nonat interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 10.10.10.1
ip access-list extended NAT_ACL
permit ip 160.16.16.0 0.0.0.255 any
permit ip 160.16.17.0 0.0.0.255 any
permit ip 160.16.18.0 0.0.0.255 any
permit ip 160.16.20.0 0.0.0.255 any
permit ip 160.16.50.0 0.0.0.255 any
deny ip any any
ip access-list extended WLAN-Guest-In
permit udp any eq bootpc any eq bootps
permit udp any any eq domain
permit tcp any any eq www
permit tcp any any eq 443
deny ip any 10.0.0.0 0.255.255.255
deny ip any 160.16.0.0 0.0.7.255
deny ip any any
route-map nonat permit 10
match ip address 110
This Config is for the Second location that needs the Voip Phones.
version 15.0
ip dhcp excluded-address 160.16.70.1 160.16.70.149
ip dhcp excluded-address 192.168.1.1 192.168.1.169
ip dhcp pool xyz
import all
network 160.16.70.0 255.255.255.0
default-router 160.16.70.1
domain-name xxxx
redundancy
policy-map VPO
class class-default
encr 3des
group 2
crypto isakmp key yyyyy address 10.10.10.10 255.255.255.224
interface Loopback0
ip address 11.1.2.1 255.255.255.0
interface Tunnel0
ip address 200.200.200.2 255.255.255.0
tunnel source 10.10.10.13
tunnel destination 10.10.10.10
ip address 10.10.10.13 255.255.255.224
ip flow ingress
ip nat outside
ip ospf cost 7
duplex auto
speed 100
ip address 192.168.1.3 255.255.255.0
ip flow ingress
ip nat inside
duplex auto
speed auto
no ip address
ip flow ingress
ip nat inside
duplex auto
speed auto
ip address 160.16.70.1 255.255.255.0
ip flow ingress
ip nat inside
no ip address
encapsulation slip
router ospf 2
network 160.16.70.0 0.0.0.255 area 1
router rip
version 2
network 192.168.1.0
no ip http server
ip http port 8125
no ip http secure-server
ip dns server
ip route 192.168.1.0 255.255.255.0 Tunnel0
permit ip 160.16.70.0 0.0.0.255 any
There are some additional routes and IP addresses assigned to the physical ports.  You can suggest to remove them remove them if needed.
This my LAB network information.
Sam.
