OSPF Stub Default Route Problem
gharehchamani
Community Member
HI
I have a non cisco router as totally stub ABR router and a cisco router that connects to that router. Although the default route LSA is in LSDB , the default route isn't coming in this router. Here are some snapshot of my router :
Routing Table: VPN1
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     10.0.0.0/8 is variably subnetted, 15 subnets, 4 masks
O       10.39.213.254/32 [110/6601] via 10.39.213.85, 00:01:51, Vlan303
O       10.39.213.253/32 [110/6001] via 10.39.213.85, 00:01:51, Vlan303
C       10.39.213.240/32 is directly connected, Loopback3
C       10.39.213.241/32 is directly connected, Loopback1
C       10.39.213.80/30 is directly connected, Vlan301
C       10.39.213.84/30 is directly connected, Vlan303
O       10.39.213.20/30 [110/11100] via 10.39.213.85, 00:01:51, Vlan303
O       10.39.213.16/30 [110/10700] via 10.39.213.85, 00:01:51, Vlan303
O       10.39.213.0/29 [110/6600] via 10.39.213.85, 00:01:51, Vlan303
O       10.39.213.12/30 [110/11000] via 10.39.213.85, 00:01:51, Vlan303
O       10.39.213.8/30 [110/10600] via 10.39.213.85, 00:01:55, Vlan303
O       10.39.213.36/30 [110/6001] via 10.39.213.85, 00:01:55, Vlan303
O       10.39.213.32/30 [110/36600] via 10.39.213.85, 00:01:55, Vlan303
O       10.34.144.0/23 [110/6001] via 10.39.213.85, 00:01:55, Vlan303
O       10.34.146.0/23 [110/6001] via 10.39.213.85, 00:01:55, Vlan303
        Summary Net Link States (Area 0.0.1.10)
Link ID         ADV Router      Age         Seq#       Checksum
0.0.0.0         10.39.195.252   1706        0x800028DC 0x0087E0
0.0.0.0         10.39.195.254   752         0x8000282C 0x00DC3A
0.0.0.0         10.39.213.241   1367        0x800000B4 0x00325F
0.0.0.0         10.47.195.252   892         0x80000D67 0x00836D
0.0.0.0         10.47.195.254   886         0x80000D67 0x007777
Has anyone any idea why these don't become the default route ?
7 Replies 7
Reza Sharifi
Hi Ahmad,
Who is the vendor for the none cisco vevice and what is the model?
Hi, It's HUAWEI ... I'm not sure about the model ...
is there adjacency between Cisco and non-cisco device?
Yes , the adjacency is full and you see the LSDB and routing table containing all inter-area routes but not the default route from the ABR with is the huawei router and the funny part is that the LSDB contains the summary 0.0.0.0/0 LSA but it doesn't become the default route !
hmm, in your "sh ip ospf data" there is
and   10.39.213.241 is configured on the loopback interface, whic means that your cisco router generate a default route as well.
please show the config part for the OSPF on cisco router.  Which role has the cisco router? is it only internal OSPF router?
Hi , This router is a internal router. Here is its ospf configuration :
router ospf 100 vrf VPN1
router-id 10.39.213.241
log-adjacency-changes
area 0.0.1.10 stub
network 10.39.213.80 0.0.0.3 area 0.0.1.10
network 10.39.213.84 0.0.0.3 area 0.0.1.10
network 10.39.213.240 0.0.0.0 area 0.0.1.10
network 10.39.213.241 0.0.0.0 area 0.0.1.10
it's strange, why there this LSDB entry in cisco's OSPF:
could it be the duplicated router-id?
is the device with IP  10.39.213.85 you Huawei router? I don'*t see in database the default route from this router-id.
