OSPF To many retransmissions
mahesh18
Level 6
Level 6
Hi all,
We have MAN conenction between two sites and both sites use OSPF  as Routing protocol.
I see on Link A and B  router following logs
000717: Mar  4 22:34:09.187 EST: %OSPF-5-ADJCHG: Process 3738, Nbr on GigabitEthernet4/4 from EXSTART to DOWN, Neighbor Down: Dead timer expired
000718: Mar  4 22:35:59.155 EST: %OSPF-5-ADJCHG: Process 3738, Nbr on GigabitEthernet4/4 from EXSTART to DOWN, Neighbor Down: Dead timer expired
000719: Mar  4 22:42:15.531 EST: %OSPF-5-ADJCHG: Process 3738, Nbr on GigabitEthernet4/4 from EXSTART to DOWN, Neighbor Down: Too many retransmissions
000720: Mar  4 22:43:15.531 EST: %OSPF-5-ADJCHG: Process 3738, Nbr on GigabitEthernet4/4 from DOWN to DOWN, Neighbor Down: Ignore timer expired
000721: Mar  4 22:45:25.620 EST: %OSPF-5-ADJCHG: Process 3738, Nbr  on GigabitEthernet4/4 from EXSTART to DOWN, Neighbor Down: Too many retransmissions
000722: Mar  4 22:46:25.620 EST: %OSPF-5-ADJCHG: Process 3738, Nbr on GigabitEthernet4/4 from DOWN to DOWN, Neighbor Down: Ignore timer expired
000723: Mar  4 22:49:09.148 EST: %OSPF-5-ADJCHG: Process 3738, Nbr  on GigabitEthernet4/4 from EXSTART to DOWN, Neighbor Down: Too many retransmissions
000724: Mar  4 22:50:09.148 EST: %OSPF-5-ADJCHG: Process 3738, Nbr  on GigabitEthernet4/4 from DOWN to DOWN, Neighbor Down: Ignore timer expired
000725: Mar  4 22:55:45.952 EST: %OSPF-5-ADJCHG: Process 3738, Nbr  on GigabitEthernet4/4 from EXSTART to DOWN, Neighbor Down: Too many retransmissions
000726: Mar  4 22:56:45.952 EST: %OSPF-5-ADJCHG: Process 3738, Nbr  on GigabitEthernet4/4 from DOWN to DOWN, Neighbor Down: Ignore timer expired
000727: Mar  4 23:00:40.885 EST: %OSPF-5-ADJCHG: Process 3738, Nbr  on GigabitEthernet4/4 from LOADING to FULL, Loading Done
Both sides show OSPF  is down due to Too many retransmissions
Can someone expalinme please what is Too many retransmissions  and how can we fix this?
Is this telco issue or something in cabling or config?
thanks
mahesh
2 Accepted Solutions
Nagendra Kumar Nainar
Hi Mahesh,
I have seen this "too many retranmission" error message along with EXSTART to DOWN, when you have MTU issue (not MTU mismatch) between the neighbors.
In other words, when your MTU on the interface is say 2000 while for some reason, the router is not able to process pakt of size 2000. In this case, when OSPF is enabled, after initial DBD mesage exchange (with MTU value of 2000 advertised in DBD ), neighbor STATE will be moved to EXSTART and will start sending actual DBD with LSA headers.This DBD packet size will be based on interface MTU. In this case, it will be 2000 which the neighbor may not be able to process. So no ACK or LSA request will be received from neighbor. This will result in moving neighbor STATE from EXSTART to DOWN and same process will continue.
Simply try sending ping traffic to size of outgoing MTU in interface and DF bit set. That will show if you are hitting MTU issue.
HTH,
Nagendra
8 Replies 8
Hi Mahesh,
HTH,
Nagendra
Thanks for reply.
how can i do the ping test and check the size of mtu?
mahesh
Hi, You need to use the extended ping command. See below
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080093f22.shtml
See also a handy MTU mismatch troubleshooting guide between two OSPF routers
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080093f0d.shtml
Hi all,
Many thanks for the update.
regards
mahesh
@Nagendra
You only discussed what's happening but you didn't mention a solution.
How do we resolve this?
I'm also getting EXSTART to DOWN. I have 9100 ip mtu configured on both ends (one Cisco and one is a different vendor).
When I configure ip mtu-ignore, the OSPF neighborship comes but, but I don't want to use mtu-ignore.
Why can't one of the routers process a 9100 mtu packet?
Hi @mfatty
The simple solution to this problem is to use same MTU on both end routers running OSPF in the case of Cisco Routers. Although this becomes a bit complex when different vendor equipment is being used as each vendor may implement implement MTU differently. For example running 'ip mtu 1500' command configured on Cisco vs Juniper router interface will not have the same implications. This is because in Cisco 20byte IP header is included in 1500 but not in Juniper.
As suggested in the earlier reply the best way to verify this is to run an extended ping sweep.
Also even if both ends of the links are matching MTU but the underlying MTU is smaller this can cause retransmission if LSU, LSR or LSAck is being sent by either of the routers and is getting dropped by intermediary devices with smaller MTU. In such a scenario and Established OSPF neighborship will be torn down after 25 retransmissions. Please refer to the link below for further details.
https://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/116119-technote-ospf-mtu-00.html
https://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/119433-technote-ospf-00.html
There are other reasons the OSPF adjacency could fail with the log message "Too many retransmissions". For example, two switches connected with a Layer 3 Port Channel, which might be misconfigured at one end, such that the Port Channel comes up, but does not have all of the constituent switchports configured correctly.
Here is an example of what I mean:
SW01#show run inter port 1
Building configuration...
Current configuration : 86 bytes
interface Port-channel1
no switchport
ip address 192.168.x.1 255.255.255.252
end
SW01#show run inter gig0/1
Current configuration : 162 bytes
interface GigabitEthernet0/1
no switchport
no ip address
negotiation auto
channel-group 1 mode on
end
SW01#show run inter gig0/2
Current configuration : 107 bytes
interface GigabitEthernet0/2
negotiation auto
end
SW01#
SW01#
%OSPF-5-ADJCHG: Process 1, Nbr 192.168.x.254 on Port-channel1 from FULL to DOWN, Neighbor Down: Dead timer expired
SW02#
%OSPF-5-ADJCHG: Process 1, Nbr 192.168.x.253 on Port-channel2 from DOWN to DOWN, Neighbor Down: Ignore timer expired
SW02#show run inter port 2
Current configuration : 116 bytes
interface Port-channel2
no switchport
ip address 192.168.x.2 255.255.255.252
no logging event link-status
end
SW02#show run inter gig0/1
Current configuration : 223 bytes
no switchport
no ip address
negotiation auto
channel-group 2 mode on
end
SW02#show run inter gig0/2
no switchport
no ip address
negotiation auto
end
SW02#
%OSPF-5-ADJCHG: Process 1, Nbr 192.168.x.253 on Port-channel2 from EXSTART to DOWN, Neighbor Down: Too many retransmissions
SW02#
The resolution in this case is to ensure that the interface GigabitEthernet0/2 on SW01 has the correct configuration added to it.
