11-03-2020 11:42 PM
We want to replace old firewall with one new FTD 1140 device managed by FMC 6.4.0.
Our network has Switch HP Aruba 2530 with two VLANs (ex. VLAN110 and VLAN150).
We created a sub-interface ex. (interface 1/2.150) on FMC, but didn’t work, it doesn't communicate Switch with the FMC. How can we make work the actual VLANs with the FMC?
How can we create VLANs on FMC to work with HP Switch? I didn’t find anything related about this.....
big thank you
Solved! Go to Solution.
11-04-2020 02:11 AM - edited 11-04-2020 02:31 AM
Hello
On the aruba interface interconneting the FW this needs t be a trunk and then assign the that trunk to the vlans on the aruba
Example: Port 1/7 conect to FW.
trunk 1/7 trk 1
vlan110
untagged trk1
vlan150
tagged trk1
11-04-2020 12:25 AM
how did you configure the subinterfaces ?
11-04-2020 12:54 AM
thank you for your answer.
hier ist what I did.
Transparent mode should be.
11-04-2020 02:01 AM
On what port it was connected ? Do you have VLAN 110 and 150 on HP switch side ?
make sure port should be (Tagger port) - cisco world as Trunk ( that means allow all the VLAN)
11-04-2020 02:13 AM
yes, I have so:
FMC int 1/2 192.168.1.253 (inside) Default VLAN
subint 1/2.150 172.30.150.254 GW
VLAN150 Printers
Port 7 Switch HP and trunk1, I tied both. (cable directly connected)
11-04-2020 02:27 AM - edited 11-04-2020 02:29 AM
Hello
@Gerald74 wrote:
yes, I have so:
VLAN150 Printers
Okay based on the above, The FW has two ip subnets (physical interface and subinterface) of port 1/2 And that physical port of the FW is connected to the aruba switch on port 7 which is a trunk?
If so look at my previous post about creating a trunk on the aruba
Hello
trunk 1/7 trk 1
vlan110
untagged trk1
vlan150
tagged trk1
11-04-2020 02:22 AM
Him Paul,
Thank you for your answer
PORT 8 on Switch is as Tunk1 (Default VLAN Untagged and VLAN150 Tagged)
11-04-2020 02:47 AM
it was my mistake. The cable was in Port1. Now the cable is on Trunk1(Port8)
now it is all ok. Thank you very much BB and Paul.
