OSPF tunneling question
hugh2_nguyen
I configured tunneling for OSPF routers but OSPF does not see further then its neighbor at the tunnel interface. That is, from the configuration below, 192.x.x.10 and 10.1.1.1 on Router4 could ping 142.x.x.10 and 10.1.1.2 on Router5 respectively and vice versa. However, none of the 192.168.x.x nodes on one router could ping any thing on the other router. Would you please give me some advice. Thanks.
hostname Router4
policy-map FQ
class class-default
fair-queue
interface Tunnel0
ip address 10.1.1.1 255.255.255.0
ospfv3 instance 64 network manet
ospfv3 1 area 0 address-family ipv4 instance 64
tunnel source GigabitEthernet0/0
tunnel destination 142.x.x.10
interface GigabitEthernet0/0
Description external WAN
ip address 192.x.x.10 255.255.255.0
duplex auto
speed auto
ipv6 enable
service-policy output FQ
interface GigabitEthernet0/1
Description internal LAN
ip address 192.168.x.40 255.255.255.0
duplex auto
speed auto
ipv6 enable
router ospfv3 1
router-id 4.4.4.4
log-adjacency-changes
address-family ipv4
timers spf 1 2
router-id 4.4.4.4
exit-address-family
ip forward-protocol nd
ip route 142.x.x.10 255.255.255.255 192.x.x.172
! 192.x.x.172 is WAN gateway
hostname Router5
policy-map FQ
class class-default
fair-queue
interface Tunnel0
ip address 10.1.1.2 255.255.255.0
tunnel destination 192.x.x.10
ip address 142.x.x.10 255.255.255.0
duplex auto
speed auto
ipv6 enable
duplex auto
speed auto
ipv6 enable
router ospfv3 1
router-id 5.5.5.5
address-family ipv4
timers spf 1 2
router-id 5.5.5.5
exit-address-family
ip route 192.x.x.10 255.255.255.255 142.x.x.172
! 142.x.x.172 is WAN gateway
8 Replies 8
Marwan ALshawi
can you please run the bellow comand in each of the ospf interface
and if did nt work can you post
show ip ospf neighbor
and
debug ip ospf adj
good luck
Here they are:
Router4#sh ospfv3 nei
OSPFv3 Router with ID (4.4.4.4) (Process ID 1)
Neighbor ID Pri State Dead Time Interface ID Interface
5.5.5.5 1 LOADING/ - 00:01:55 10 Tunnel0
Router4#debug ospfv3 adj
OSPFv3 adjacency events debugging is on
i think you may have a MTU mismatch problem
can you make sure all the interfaces have the same mtu
or in the interface level of each interface participating in opsf even the tunnel
use the commend
ip ospf mtu-ignore
again can you configure ospf without the v3
interface
ip ospf 1 area 0
ip ospf mtu-igonre
by the way the wan link address like 142.x.x.10
is it reachable wuithout the tunnel ?
and let me know
good luck
I agree that this problem may be related to MTU, but the problem 'ip ospf mtu-ignore' solves is related to MTU mismatch and, in this case, the neighbor state stops at 'exstart'. but here the state reach 'loading'.
So, I suggest you configure 'ip mtu 1400' on each Tunnel interface and check again.
Also, it can be helpful to do some pings with a large packet size (1400 or so) to see if there is no packet loss on tunnels.
For last, enable the following debugs, clear the ospf process and post the output here. That is
# undebug all
# term moni (if you aren't in the console)
# debug ip ospf adj
# debug ip ospf retrans
# clear ip ospf process
Hope that helps.
Paulo Roque
I tried both "ip ospf mtu-ignore" and "ip mtu 1400" and neither solved the problem. I still could not ping from 192.168.x.x to the other side. Ping tunnel interface to tunnel interface with 1400-byte message worked fine but if ping messages are larger than 1400 then some pings were loss. Here're some debug data:
Router5# debug ospfv3 adj
Router5#
*Oct 1 16:49:04.749: OSPFv3: Tunnel0 Nbr: 4.4.4.4: Retransmitting LS REQ
*Oct 1 16:49:04.749: OSPFv3: put LS request for LSID 0.0.0.0, type 2001, adv. rtr. 4.4.4.4 in LS REQ packet
*Oct 1 16:49:04.749: OSPFv3: put LS request for LSID 0.0.0.10, type 8, adv. rtr. 4.4.4.4 in LS REQ packet
*Oct 1 16:49:04.749: OSPFv3: put LS request for LSID 0.0.0.0, type 2009, adv. rtr. 4.4.4.4 in LS REQ packet
*Oct 1 16:49:04.749: OSPFv3: Send LS REQ to 4.4.4.4 length 36 LSA count 3
*Oct 1 16:49:04.985: OSPFv3: Rcv LS REQ from 4.4.4.4 on Tunnel0 length 52 LSA count 3
*Oct 1 16:49:04.985: OSPFv3: Send UPD to FE80::219:6FF:FE66:6330 on Tunnel0 length 136 LSA count 3
*Oct 1 16:49:09.469: OSPFv3: Tunnel0 Nbr: 4.4.4.4: Retransmitting LS REQ
*Oct 1 16:49:09.469: OSPFv3: put LS request for LSID 0.0.0.0, type 2001, adv. rtr. 4.4.4.4 in LS REQ packet
*Oct 1 16:49:09.469: OSPFv3: put LS request for LSID 0.0.0.10, type 8, adv. rtr. 4.4.4.4 in LS REQ packet
*Oct 1 16:49:09.469: OSPFv3: put LS request for LSID 0.0.0.0, type 2009, adv. rtr. 4.4.4.4 in LS REQ packet
*Oct 1 16:49:09.469: OSPFv3: Send LS REQ to 4.4.4.4 length 36 LSA count 3
*Oct 1 16:49:09.733: OSPFv3: Rcv LS REQ from 4.4.4.4 on Tunnel0 length 52 LSA count 3
*Oct 1 16:49:09.733: OSPFv3: Send UPD to FE80::219:6FF:FE66:6330 on Tunnel0 length 136 LSA count 3
*Oct 1 16:49:14.269: OSPFv3: Tunnel0 Nbr: 4.4.4.4: Retransmitting LS REQ
*Oct 1 16:49:14.269: OSPFv3: put LS request for LSID 0.0.0.0, type 2001, adv. rtr. 4.4.4.4 in LS REQ packet
*Oct 1 16:49:14.269: OSPFv3: put LS request for LSID 0.0.0.10, type 8, adv. rtr. 4.4.4.4 in LS REQ packet
*Oct 1 16:49:14.269: OSPFv3: put LS request for LSID 0.0.0.0, type 2009, adv. rtr. 4.4.4.4 in LS REQ packet
*Oct 1 16:49:14.269: OSPFv3: Send LS REQ to 4.4.4.4 length 36 LSA count 3
*Oct 1 16:49:18.981: OSPFv3: Rcv LS REQ from 4.4.4.4 on Tunnel0 length 52 LSA count 3
*Oct 1 16:49:18.981: OSPFv3: Send UPD to FE80::219:6FF:FE66:6330 on Tunnel0 length 136 LSA count 3
*Oct 1 16:49:19.073: OSPFv3: Tunnel0 Nbr: 4.4.4.4: Retransmitting LS REQ
*Oct 1 16:49:19.073: OSPFv3: put LS request for LSID 0.0.0.0, type 2001, adv. rtr. 4.4.4.4 in LS REQ packet
*Oct 1 16:49:19.073: OSPFv3: put LS request for LSID 0.0.0.10, type 8, adv. rtr. 4.4.4.4 in LS REQ packet
*Oct 1 16:49:19.073: OSPFv3: put LS request for LSID 0.0.0.0, type 2009, adv. rtr. 4.4.4.4 in LS REQ packet
*Oct 1 16:49:19.073: OSPFv3: Send LS REQ to 4.4.4.4 length 36 LSA count 3
*Oct 1 16:49:23.521: OSPFv3: Rcv LS REQ from 4.4.4.4 on Tunnel0 length 52 LSA count 3
*Oct 1 16:49:23.521: OSPFv3: Send UPD to FE80::219:6FF:FE66:6330 on Tunnel0 length 136 LSA count 3
*Oct 1 16:49:23.789: OSPFv3: Tunnel0 Nbr: 4.4.4.4: Retransmitting LS REQ
*Oct 1 16:49:23.789: OSPFv3: put LS request for LSID 0.0.0.0, type 2001, adv. rtr. 4.4.4.4 in LS REQ packet
*Oct 1 16:49:23.789: OSPFv3: put LS request for LSID 0.0.0.10, type 8, adv. rtr. 4.4.4.4 in LS REQ packet
Router5# debug ospfv3 retrans
OSPFv3 retransmission events debugging is on
Router5#sh ospfv3 nei
OSPFv3 Router with ID (5.5.5.5) (Process ID 1)
4.4.4.4 1 LOADING/ - 00:01:56 10 Tunnel0
*Oct 1 16:53:27.161: %OSPFv3-5-ADJCHG: Process 1, Nbr 4.4.4.4 on Tunnel0 from L
OADING to DOWN, Neighbor Down: Too many retransmits
Hi hugh2_nguyen.
You have a problem with your link or problem with MTU. The simptons show that.
Just to make sure ... have you set the df-bit when pinging the other side? I mean
'ping 1.1.1.1 df-bit repeat 1000 size 1400'.
Also, I insist, try a smaller MTU link on both the tunnel int. Maybe 1000 bytes.
If it still does not work, check for error on interfaces.
A 'show int' on both Gi and Tu interfaces of both routers may help. Or may be a congested link between the both.
marwanshawi and Paolo,
I connected two laptops to the two WAN gateways and I could stream video through the WAN although the bandwidth of the WAN is very limited (less than 1Mbps).
I'll try your suggestions later today and let you know the results. I'll try with ospf but eventually I have to run ospfv3 since user applications are IPv6. Thanks.
Hugh
if you want to estblish ipv6 routing over ipv4 netwrk
you need:
1- enable ipv6 routing
ipv6 unicast-routing
2- give each tunnel an ipv4 address in the same subnet
3- use tunnel mode as ipv6ip ( less overhead)
underthe tunnel enable osofv3 like
ipv6 ospfv3 area 0
