SDM does not work properly
hsauwcusa
Community Member
Some buttons in SDM began to stop working.
"Additional Task" does not show any contents. Edit button on a certain page does not work. I think I stalled it on the router.
I reinstalled java script, but it did not solve it.
Should I just run the installation CD to overwrite the program in the router?
Is my configuration safe?
Thank you.
Lucien Avramov
Level 11
Level 11
if SDM starts, the install on the router is good.
This is most likely due to not using the supported java runtime environment JRE version.
SDM does not support java after: 6u3.
Cisco SDM requires Sun Java Runtime Environment (JRE). The following versions are supported:
•JRE 1.5_09
•JRE1.4.2_08
•JRE 1.5.0_06
•JRE 1.5.0_07
•JRE 1.6.0_02
•JRE 1.6.0_03
As per the release notes.
http://www.cisco.com/en/US/docs/routers/access/cisco_router_and_security_device_manager/software/release/notes/SDMr25.html
Also configuration guide may be handy:
http://www.cisco.com/en/US/docs/routers/access/cisco_router_and_security_device_manager/25/software/user/guide/SDM25UGD.html
Thank you so much for your explanation. This is exactly what I needed to know. My java was latest, 6u16, which was out of support.
I will find and install the versions you mentioned above.
Thanks again.
