OSPF Virtual link design issue
mahesh18
Level 7
Level 7
Hi all,
I have  the Lab setup  like below
R1  area 0
R2 is ABR area 0 and 20
R3 is connected to R2 and R4 in Area 20 only.
R3 is an ASBR *****************************************************************************************************
R4 is connected to R3 and R5  Area  20 and area 12 only.
R5 is Area 12 only connected to R4.
R5 is an ASBR *******************************************************************************************************
I have created Virtual link between R2 and R4  but link on both ends shows down.
Message was edited by: mahesh parmar
4 Accepted Solutions
So, here it is. try a link between r5 and r2.  You virtual link would transit through area 20
bogdan.radu
Community Member
Hi Mahesh,
The purpose of defining a virtual link is to "connect" an area to Area 0. If I understand correctly from your post, you have Area 12 which is not directly connected to Area 0. In this case, you have to make a virtual link between one of the ABRs of Area 0 to one of the ABRs of Area 12.
In the above case, you have to make a virtual link between R2 and R3 and it will look like that:
R2:
router ospf 1
router-id 2.2.2.2
log-adjacency-changes
area 20 virtual-link 3.3.3.3
network 10.10.12.2 0.0.0.0 area 0
network 10.10.23.2 0.0.0.0 area 20
R2#sh ip os int b
Interface    PID   Area            IP Address/Mask    Cost  State Nbrs F/C
VL0          1     0               10.10.23.2/24      10    P2P   1/1
Fa0/0        1     0               10.10.12.2/24      10    DR    1/1
Fa0/1        1     20              10.10.23.2/24      10    BDR   1/1
R3:
router ospf 1
router-id 3.3.3.3
area 20 virtual-link 2.2.2.2
network 10.10.23.3 0.0.0.0 area 20
network 10.10.34.3 0.0.0.0 area 12
R3#sh ip os int b
VL0          1     0               10.10.23.3/24      10    P2P   1/1
Fa0/0        1     12              10.10.34.3/24      10    BDR   1/1
Fa0/1        1     20              10.10.23.3/24      10    DR    1/1
Now, R3 virtually has an interface in Area 0, even though it is not connected to Area 0.
Hope this helps.
Hey Mahesh18,
Based on the information you've provided above...below I've drawn your OSPF design (dashed line is the virtual link).
If my drawing is accurate then the following steps will connect area 12 to area 0 and get you on your way.  Note:  This assumes all interfaces are up and reachable.
1. On R4 - under the OSPF process configure the following
          -  area 20 virtual-link [R2 router-id]
2. On R2 - uncer the OSPF process configure the following
          - area 20 virtual-link [R4 router-id]
That's all there is...  Hope this helps!
20 Replies 20
Mahesh,
umm where you setting up the virtual link seems to be ok. umm cant tell unless we see some more information. hows the ip addressing and all . Are the devices able to see each other. I mean R2 and R3.
Maybe this link will give some information on virtual links
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00801ec9ee.shtml
can you please post a diagram so that its more clear how its all connected.
Regards, Kishore
Hi Kishore,
Unfortunately i have no diagram yet.
R2 can only see R3s interface which are directly connected.
R2 is unable to see the interface IP of R3 which connects to R4.
MAhesh
Hi Mahesh,
Is this your setup?
If yes, you need a virtual link between r5 and r2
Hi Reza,
My setup is like this
R1 is in Area 0 and has physical connection to R2.
R2 has 1 interface in area 0 and 1 interface in area 20.
R3 has 2 physical interfaces and they are connected to R2 and R4.
R3 is in area 20 only.
R4 has 1 interface in area 20 and 1 interface in area 12.
R5 has physical connection to R4 .
R5 is in area 12 only.
I hope this helps
MAhesh
Let me try  link betwwen r5 and r2
thanks
Hi Reza,
Thanks for making nice diagram.
I tried between R2 and R5 using area 20 still down.
Just let you know R3 and R5 are ASBR *******************
i am not sure that will have any effect on virtual link or not?
thanks
MAhesh
Hi Reza,
I created Virtual link between R5 and R2 using area 20 still it is down down
Hi Reza,
I read the document and now tried virtual  link between R2 and R2 area 20 still down down
MAhesh
Hi Mahesh,
Do you mean r2 and r5?
r3 and r4 are already connected to area 0, so you would need a virtual link from r5 to r2 transiting r4.
Hi Reza,
As per your 2nd diagram i tried r 2 and r5 then r2 and r4 still no luck
thanks
mahesh
daudparvez
Level 3
Level 3
Dear Mahesh,
You havent mentioned Area 2 in your topology description, whereas your " shows ip ospf" shows one of your interfaces in Area 2.
Hi Daud,
  Area BACKBONE(0) (Inactive)
        Number of interfaces in this area is 2 (1 loopback) *****************************
This tells number of interaces in this area is 2 not area number if i am correct.
MAhesh
