OSPF with etherchannel
RabihNaddaf9078
Hello every one! I'm preparing to take my icnd2 exam next week .while I'm trying to implement Wendel Odom examples on packet tracer I had a problem . Router 1 can't see Router 0 as an ospf neighbor. something wrong between switches(4 and 5) and I couldn'r figure out what it is,someone helps me please and thanks.Untitled2.jpg
switch 5
Switch#show running-config
Building configuration...
Current configuration : 1177 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
spanning-tree mode pvst
interface Port-channel2
interface FastEthernet0/1
switchport mode trunk
interface FastEthernet0/2
channel-group 2 mode on
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
Switch#
switch 4
Current configuration : 1203 bytes
version 12.2
hostname Switch
interface Port-channel1
channel-group 1 mode on
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
Switch#
router 1
Router#show running-config
Current configuration : 1109 bytes
version 15.1
hostname Router
no ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX152417RX-
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.341
encapsulation dot1Q 341
ip address 10.1.3.1 255.255.255.128
interface GigabitEthernet0/0.342
encapsulation dot1Q 342
ip address 10.1.3.129 255.255.255.128
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
interface Serial0/3/0
ip address 10.1.13.3 255.255.255.128
clock rate 2000000
interface Serial0/3/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 10.0.0.0 0.255.255.255 area 0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
Router#
router 0
Current configuration : 1089 bytes
version 15.1
hostname Router
no ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX15242583-
no ip address
duplex auto
speed auto
ip address 10.1.3.2 255.255.255.128
ip address 10.1.3.130 255.255.255.128
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
ip address 10.1.24.3 255.255.255.128
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Router#
Mark Malone
theres no OSPF config on sw4 and sw5 or am i missing something posted ? It would be required to create the neighbour relationship between both switches
Mark Malone
