Out of memory errors on stacked 3750's
brian.kennedy
We have 6 sets of stacked (2) 3750's that have seemed to all have a memory leak/problem. Not sure if the error occurred all at the same time, but we noticed the problem when CWSI couldn't contact them anymore on a scheduled inventory collection. These all have dual connected (port-channeled) servers connected to them and they are dual (port-channeled) back to a pair of 6509's. Due to the memory error, we are unable to console/telnet into them to find out more on the memory problem. A reboot clears it, but as these all have critical servers on them, that is not an easy option. My biggest question is whether any knows if there is a problem with memory leaks on the code they are running (12.2.25 SE) and whether upgraded code would resolve this?
Danilo Dy
That IOS has bug, used it in one deployment and found out later its being deferred (DF). My problem is not the same though. Get a new version and upgrade it, get a 12.2.35 SEn (n stand for number 1, 2, or 3)
hoogen_82
Level 4
Level 4
It is best to post the show version when such questions are asked. We could be specific in givein you answers then..
Cheers
Hoogen
