Output drops Cisco interface
on my Cisco WS-C2960-48TC-S i have 82933027 output drops on the access interface.
this interface is connected to only one computer, does someone have an idea how this is posible ??
L2_HHP-21#sh int fa0/12
FastEthernet0/12 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is d4a0.2a6c.6236 (bia d4a0.2a6c.6236)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 2/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 82933027
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  5 minute output rate 997000 bits/sec, 202 packets/sec
     161016 packets input, 20059528 bytes, 0 no buffer
     Received 12237 broadcasts (8646 multicasts)
     0 watchdog, 8646 multicast, 0 pause input
     90278417 packets output, 25066682913 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Switch#sh run int fa0/12
Building configuration...
Current configuration : 168 bytes
interface FastEthernet0/12
 switchport access vlan 30
 switchport mode access
 switchport voice vlan 244
 spanning-tree portfast
 spanning-tree bpduguard enable
end
L2_HHP-21#sh mac add int fa0/12
          Mac Address Table
Vlan    Mac Address       Type        Ports
  30    0010.f32e.6236    DYNAMIC     Fa0/12
Total Mac Addresses for this criterion: 1
8 Replies 8
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Generally it's caused by sending packets to the interface faster than they can egress the interface.
On some switches, I think the 2960 being one of them, QoS being enabled on the switch, in a default configuration, often results in premature packet dropping due to default buffer reservations for QoS egress queues.
Hello joseph thank you for your answer.
I have checked the global configuration but no QOS settings are enabled.
The output drops are not really high but i still have them.
This morning i reset the counters and now i have again "output drops: 2956"
it is just an interface connected to a computer so it is strange that it has the output drops.
FastEthernet0/2 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is a456.308c.3102 (bia a456.308c.3102)
     reliability 255/255, txload 12/255, rxload 1/255
  Last clearing of "show interface" counters 05:19:54
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 2956
  5 minute output rate 4829000 bits/sec, 861 packets/sec
     10314 packets input, 1015389 bytes, 0 no buffer
     Received 1674 broadcasts (1373 multicasts)
Fa0/2                        connected    30         a-full  a-100 10/100BaseTX
sh mac add int fa0/2
          Mac Address Table
  30    0010.f325.e554    DYNAMIC     Fa0/2
What's the output packet count (that corresponds to your drop count)?
could you explain a little bit more, where can i find the output count ?
There are several bugs I've read where the output drops are "cosmetic". Can you specify what IOS you are running?
Hello Leo thank you for your answer.
The iios version is: c2960-lanlitek9-mz.122-50.SE5.bin
Michael,
Upgrade your IOS to 12.2(55)SE8.
the thing is, the output drops just occur sometimes.
like now it did not have any additional output drops for 1 hour, the count stays at 2956 so it is sometimes.
