Output drops in 7200 gig interface
Haris P
Level 4
Level 4
Dears ,
I have too much output drops in my cisco 7206 VxR NPE G1 router .
I'm doing dot1Q on this interface and is connected to  switch , i changed the router and IOS but still the error is same . What can be the reason . The interface on switch and router are 1000/Full and i changed the cable also . The traffic only comes about  max70Mbps and it is really confusing .
I will rate the useful answers
GigabitEthernet0/3 is up, line protocol is up
  Hardware is BCM1250 Internal MAC, address is
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 17/255, rxload 10/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 04:32:37
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3519327
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 39407000 bits/sec, 13506 packets/sec
  5 minute output rate 68839000 bits/sec, 15108 packets/sec
     218011118 packets input, 4156468935 bytes, 0 no buffer
     Received 1502964 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 2116357 multicast, 0 pause input
     236105298 packets output, 865690632 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 0 pause output
Haris P
10 Replies 10
paolo bevilacqua
This happens with traffic bursts,. You donn't see that, but youre exceeding interface bandwith.
Aslo since you have flow control enabled, check attached device what is sending.
I have many devices attached on this interface .may be about 100 dot1Q
subinterfaces with service policy . Whether this will make problem?
Is there is anyway to know which sub-interface is making the problem?
interface GigabitEthernet0/3.12
encapsulation dot1Q 12
ip address 10.10.10.1 255.255.255.252
service-policy input 1M
service-policy output 1M
interface GigabitEthernet0/3.13
encapsulation dot1Q 13
ip address 10.10.10.5 255.255.255.252
service-policy input 2M
service-policy output 2M
Haris P
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
If your only showing an average utilization of 70 Mbps on a gig interface, as Paolo describes, very likely it's transient bursts.  To better deal with such, you might want to increase your output queue depth up from the default of 40; try 1024.  (NB: if 1,024 seems large, that's about 12 ms for 1500 byte packets @ gig.)
I tried changing , input /output queue to 512 and also to 1024 ,clear the
interface counters but still there is drops
reliability 255/255, txload 11/255, rxload 7/255
Last clearing of "show interface" counters 00:00:56
Input queue: 0/512/0/0 (size/max/drops/flushes); Total output drops: 4522
Output queue: 0/512 (size/max)
5 minute input rate 27776000 bits/sec, 9725 packets/sec
5 minute output rate 45021000 bits/sec, 11001 packets/sec
539060 packets input, 191303123 bytes, 0 no buffer
Received 2292 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 5194 multicast, 0 pause input
Disclaimer
Posting
I didn't write it would totally eliminate them, but has the drop percentage decreased?  (Can't tell from you latest stats as you didn't provide total output packets.)
PS:
BTW, I see you have subinterface policies.  What's the stats and configurations for those?
The below is the output drops when i tried changing the queue to 512 ,note that i cleared the counters just 1 min ago
Yes i do have policies on sub-interface ,it is just to control the BW . Is there is any way to find the drops under each sub-interface ?
     596900 packets output, 308703970 bytes, 0 underruns
policy-map 2M
  class class-default
   police 2048000 conform-action transmit  exceed-action drop
policy-map 1M
  class class-default
   police 1024000 conform-action transmit  exceed-action drop
Disclaimer
Posting
Oh, that does change expectations!
You drops are likely policing drops, and if they are, increasing the output queue won't decrease them.
Try a show policy-map interface command for its stats.
Seems like my drops are due to do policing .
Haris P
Good answer.
Same as me, it drop due to the policy-map
Dear Haris,
Could you please click Correct Answer to troubleshoot quickly for other?
Thank you very much.
Try lowering the speed to 100.
