Output drops increasing on Cisco 2900
ankurjain05
i have a cisco 2911 router with 100M ethernet link.
The bandwidth is below 200/255, even than the output drops are increasing.
The CPU process is normal. I cannot find out a cause for the same.
Can someone help.
Leo Laohoo
Post the complete output to the command "sh interface <PORT>".
Hello, thanks for your response.
It's below
WAN
GigabitEthernet0/0 is up, line protocol is up
Hardware is CN Gigabit Ethernet, address is fc99.47d2.6a23
Internet address is y.y.y.y
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 133/255, rxload 153/255
Keepalive set (10 sec)
Full Duplex, 100Mbps, media type is RJ45
output flow-control is unsupported, input flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 8w5d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 12467088
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 60153000 bits/sec, 10013 packets/sec
5 minute output rate 52486000 bits/sec, 9139 packets/sec
1773082824 packets input, 228644216 bytes, 12465408 no buffer
Received 4407 broadcasts (0 IP multicasts)
41034 input errors, 0 CRC, 0 frame, 41034 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
734288434 packets output, 2057901035 bytes, 0 underruns
1 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
LAN
GigabitEthernet0/1 is up, line protocol is up
Hardware is CN Gigabit Ethernet, address is fc99.47d2.232f
Internet address is x.x.x.x
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 15/255, rxload 13/255
Full Duplex, 1Gbps, media type is RJ45
output flow-control is XON, input flow-control is XON
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 7448
5 minute input rate 52453000 bits/sec, 9137 packets/sec
5 minute output rate 59760000 bits/sec, 9967 packets/sec
730590851 packets input, 475917465 bytes, 7441 no buffer
Received 3565224 broadcasts (0 IP multicasts)
0 watchdog, 3211148 multicast, 381 pause input
1762758372 packets output, 2858399586 bytes, 0 underruns
97808 unknown protocol drops
0 lost carrier, 0 no carrier, 100373 pause output
This means that packets meant to go through the WAN link is being dropped by the router.
What is the WAN bandwidth configred ?
-GI
