05-11-2020 12:37 AM
Hi All
I have a 3650 and a 3750 linked together via a port channel and I am getting output drops on the 3650 side of the port channel. I ahve placed some info below, let me know if you need any more data to help me troubleshoot why I am getting Tx errors on the one switch.
Switch Ports Model SW Version SW Image Mode
* 1 28 WS-C3650-24TD 03.06.04.E cat3k_caa-universalk9 INSTALL
Some show commands:
show system mtu
Global Ethernet MTU is 1500 bytes.
show run | inc soft
qos queue-softmax-multiplier 200
Port configuration:
interface GigabitEthernet1/0/24
description net-cbs-prd-001_1/0/24
switchport mode trunk
channel-protocol lacp
channel-group 50 mode active
end
interface GigabitEthernet1/0/23
description net-cbs-prd-001_2/0/24
end
Port-channel50 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 00f6.63e2.fb97 (bia 00f6.63e2.fb97)
MTU 1500 bytes, BW 2000000 Kbit/sec, DLY 10 usec,
reliability 250/255, txload 2/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is
input flow-control is off, output flow-control is unsupported
Members in this channel: Gi1/0/23 Gi1/0/24
Last input 00:00:00, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 9884000 bits/sec, 1695 packets/sec
5 minute output rate 18096000 bits/sec, 3407 packets/sec
353968677024 packets input, 369281676384302 bytes, 0 no buffer
Received 1255496791 broadcasts (1013407362 multicasts)
0 watchdog, 1013407362 multicast, 0 pause input
400826175206 packets output, 383363433855944 bytes, 0 underruns
1062078557 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
* 1 28 WS-C3750G-24TS 12.2(55)SE5 C3750-IPBASEK9-M
2 28 WS-C3750G-24TS 12.2(55)SE5 C3750-IPBASEK9-M
Some show commands:
Port Configuration:
description net-ics-prd-002_1/0/24
channel-group 42 mode active
end
interface GigabitEthernet2/0/24
description net-ics-prd-002_1/0/23
end
Port-channel42 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 000f.8fd5.a618 (bia 000f.8fd5.a618)
MTU 9000 bytes, BW 2000000 Kbit, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 2/255
Full-duplex, 1000Mb/s, link type is auto, media type is unknown
Media-type configured as connector
Members in this channel: Gi1/0/24 Gi2/0/24
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3650699
5 minute input rate 18648000 bits/sec, 3417 packets/sec
5 minute output rate 9881000 bits/sec, 1687 packets/sec
417435748682 packets input, 405214976425882 bytes, 0 no buffer
Received 5004004048 broadcasts (2928468163 multicasts)
0 watchdog, 2928468163 multicast, 0 pause input
363670706828 packets output, 378337160283941 bytes, 0 underruns
0 output errors, 0 collisions, 5 interface resets
05-11-2020 01:02 AM
Upgrade the IOS to something more recent first.
Please take the time to read the following:
05-11-2020 01:50 AM
the reliablity should be 255/255, if it is not, it could indicate a physical problem. Which of the two interfaces in the 3560 port channel are showing errors as well ? Try and use another port and/or cable for the port channel on the 3560, in order to find out if the problem is with one of the ports on the 3560...
--> reliability 250/255, txload 2/255, rxload 1/255
05-11-2020 02:49 AM
Thanks for the heads up, I will check to see if its a physical issue, let me know if the below troubleshooting process is a good one
