09-17-2015 12:03 AM - edited 03-08-2019 01:49 AM
hi,
i've got a 3560X switch and 'weirded' out by this output.
i don't see this on older switches like 3560/3750 etc.
what does seq_no:0 mean?
#sh mac add int g0/24
Mac Address Table
Vlan Mac Address Type Ports
1 e41f.13ea.5123 DYNAMIC Gi0/24 seq_no:0
Solved! Go to Solution.
09-17-2015 12:17 AM
John,
Nothing to worry here. The Sequ number field was used by dev team(debuging during initial phase). It has certianly no impact and is a cosmetic issue.
Kindy upgrade to 15.2(1)E1 or higher than this and you will not see.
Inayath
**********please do not forget to rate the post if helpfull*****
09-17-2015 12:17 AM
John,
Inayath
