Over flow errors on Trunk port
mahesh18
Level 6
Level 6
Hi all,
We have 6509 CatOS switch which has port 3/4 and 4/4 as Trunk Ports.
I did sh top util and found that trunk ports have over flow of 2977 and 18384
sh top util
Start Time: Oct 23 2008 01:00:50
End Time: Oct 23 2008 01:01:21
PortType: all
Metric: util
Port Band- Uti Bytes Pkts Bcst Mcst Error Over
width % (Tx + Rx) (Tx + Rx) (Tx + Rx) (Tx + Rx) (Rx) flow
3/4 1000 52 3828819509 4143556 107 87 0 2977
4/4 1000 52 3827944183 3871984 361 41 0 18384
4/10 1000 23 1682352358 2170815 0 22 0 0
4/9 1000 22 1684904158 1889195 0 24 0 0
3/10 1000 20 1496081772 1680064 0 43 0 0
3/9 1000 19 1413357924 1893167 0 40 0 0
4/1 1000 18 1321609045 1572700 287 130 0 0
3/16 1000 17 1277460950 3456256 1904 384 0 0
3/1 1000 17 1301223616 1604332 348 201 0 0
4/2 1000 9 672742599 1764039 430 72 0 0
3/2 1000 8 618549461 1691276 522 227 0 0
4/3 1000 6 505162023 436374 383 146 0 0
So what does over flow mean.
Is it some type of error on switch?
many thanks
Mahesh
glen.grant
Buffer Overflow means that the port receivesg more traffic than it can store in its buffer. This can be caused a bursty traffic, as well an overrun of buffers. The suggested action is to decrease the transmission of the source device.
If its just very slowly incrementing its probably not a problem and just due to bursty traffic , clear the counters and keep an eye on it for a few days.
glen.grant
Hi glen,
thanks for reply.
I cleared the counters still it is increasing
rapidly so i can ignore this as it is not serious issue?
Mahesh
