PA-MC-8T1 not working
yogi
I have a C6509NEB Sup1/MSFC1 that we just switched from hybrid to native mode. Loaded c6sup11-pk2s-mz.121-27b.E.bin
From best I can tell this should be supported.
Error - Card in slot 7 is unsupported. The image for the card is not bundled in image.
drolemc
Level 6
Level 6
The problem may cause two reasons.
1. Port Adapater is not working
2. Memory leak on some sort with that image
solution is upgrade the image
