Packet Analysis on cisco Nexus3500 C3548P-10GX Chassis
EArohitsingh
Hi. Following are the details of the switch
Intel(R) Core(TM) i3- CPU @ 2.50GHz with 16396528 kB of memory.
Processor Board ID FOC25244X6C
We were interested in doing the analysis of packets (particularly TCP/UDP) on the switch to diagnose the issue of packet drops. Capturing Packet and saving it doesn't seem a feasible option on this particular Hardware.
Was wondering if there exists a way to analyze TCP/UPD packets on the particular switch, with/without capturing packet.
Jan Rolny
Level 3
Level 3
have you tried "ethanalyzer local"?
Detailed description is on link below:
https://community.cisco.com/t5/networking-knowledge-base/using-ethanalyzer-on-nexus-platform-for-control-plane-and-data/ta-p/3142665
Best regards,
Jan
Pavel Tarakanov
One of the option - ethanalyzer, but it will be able to capture only control plane traffic (punted to CPU).
Other option - SPAN to one of the ports. Details can be found in configuration guide:
https://www.cisco.com/c/en/us/td/docs/dcn/nx-os/nexus3548/103x/configuration/system-management/cisco-nexus-3548-switch-nx-os-system-management-configuration-guide-103x/m-configuring-span.html
EArohitsingh
Thanks for the reply @Jan Rolny and @Pavel Tarakanov. The ethanalzyer couldn't capture TCP/UDP
Spoiler
  • The control plane uses protocols such as OSPF, BGP, and MPLS to exchange information between network devices.
  • The data plane, however, employs protocols such as Ethernet, TCP/IP, and UDP to transmit data packets between network devices.
Is there any other alternative apart from using SPAN?
packet-tracer is also not working.
