04-06-2022 05:17 AM
I am facing a problem of random packet loss only to the management interface (VLAN104) of SG-350 switches.
The physical connectivity is like,
17 VLANs created on Fortigate FG-100E port15
The FG-100E 15th port is connected to a trunk port (Gi24) on SG-350 (Core Switch).
Ports on the SG-350 (Core Switch) are configured as TRUNK and connected to (Uplink) the 21 access switch's trunk ports.
VLAN-104 is the management VLAN and is assigned 192.168.14.0/24 range IPs to all the management VLAN Interfaces on switches.
Ping to the core switch has no drops.
But ping to the rest of switch's management VLAN interface has packet drops.
But, Ping to computers connected to the same VLAN-14 has no packet drop issues.
Please see the configurations below and help me to identify the root cause as well as a solution.
Core switch Config
SW-SG350-19#sh running-config
config-file-header
SW-SG350-19
v2.4.0.91 / RTESLA2.4_930_181_042
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
unit-type-control-start
unit-type unit 1 network gi uplink none
unit-type-control-end
vlan database
vlan 100-117
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
bonjour interface range vlan 1
hostname SW-SG350-19
username admin password encrypted 7221b4013c19eacdc8ad2ccee60acfc1dc8c61d7 privilege 15
ip ssh server
no ip http server
interface vlan 100
name Server_01
interface vlan 101
name server_02
interface vlan 102
name VoIP
interface vlan 103
name Local_Restricted
interface vlan 104
name Access_Control
ip address 192.168.14.169 255.255.255.0
interface vlan 105
name Management
interface vlan 106
name General_Dept
interface vlan 107
name Marketing
interface vlan 108
name Big_Data
interface vlan 109
name ML-Team
interface vlan 110
name Design_Dev
interface vlan 111
name Annotation
interface vlan 112
name Guest-Wi-Fi
interface vlan 113
name Reserved_02
interface vlan 114
name Reserved_03
interface vlan 115
name Reserved_04
interface vlan 116
name Reserved_05
interface vlan 117
name Reserved_06
interface GigabitEthernet2
switchport mode trunk
interface GigabitEthernet4
interface GigabitEthernet5
interface GigabitEthernet6
interface GigabitEthernet7
interface GigabitEthernet8
interface GigabitEthernet9
interface GigabitEthernet10
interface GigabitEthernet11
interface GigabitEthernet12
switchport access vlan 104
interface GigabitEthernet13
switchport access vlan 102
interface GigabitEthernet14
interface GigabitEthernet15
interface GigabitEthernet16
interface GigabitEthernet17
interface GigabitEthernet18
switchport access vlan 113
interface GigabitEthernet19
spanning-tree link-type point-to-point
macro description "switch "
!next command is internal.
macro auto smartport dynamic_type unknown
interface GigabitEthernet20
interface GigabitEthernet21
interface GigabitEthernet22
interface GigabitEthernet23
interface GigabitEthernet24
interface GigabitEthernet25
interface GigabitEthernet26
exit
banner login ^C
UNAUTHORIZED ACCESS TO THIS DEVICE IS PROHIBITED
You must have explicit, authorized permission to access or configure this device.
Unauthorized attempts and actions to access or use this system may result in civil and/or
criminal penalties.
All activities performed on this device are logged and monitored.
^C
macro auto disabled
ip default-gateway 192.168.14.11
Access Switch Configuration
Using username "admin".
You must have explicit, authorized permission to access or configure this device .
Unauthorized attempts and actions to access or use this system may result in civ il and/or
criminal penalties.
User Name:admin
Password:*************
SW-SG350-08#sh running-config
config-file-header
SW-SG350-08
CLI v1.0
ssd-control-start
ssd config
vlan database
vlan 100-117
exit
dot1x system-auth-control
hostname SW-SG350-08
line console
exec-timeout 0
exit
line ssh
exec-timeout 0
exit
line telnet
exec-timeout 0
exit
encrypted radius-server host 192.168.14.150 key 27wScXv855Wbu7OZmy2rvopsVpPIMVybmQc6QEzLUkM=
no passwords complexity enable
ip ssh server
ip http timeout-policy 0
no ip http server
clock timezone " " +5 minutes 30
clock dhcp timezone
ip telnet server
interface vlan 100
name Server_01
interface vlan 101
name server_02
interface vlan 102
name VoIP
interface vlan 103
interface vlan 104
name Access_Control
ip address 192.168.14.158 255.255.255.0
interface vlan 105
name Management
interface vlan 106
name General_Dept
interface vlan 107
name Marketing
interface vlan 108
name Big_Data
interface vlan 109
name ML-Team
interface vlan 110
name Design_Dev
interface vlan 111
name Annotation
interface vlan 112
name Guest-Wi-Fi
interface vlan 113
name Reserved_01
interface vlan 114
name Reserved_02
interface vlan 115
name Reserved_03
interface vlan 116
name Reserved_04
interface vlan 117
name Reserved_05
dot1x host-mode multi-sessions
dot1x reauthentication
dot1x authentication mac
dot1x radius-attributes vlan static
dot1x port-control auto
interface GigabitEthernet3
exit
macro auto disabled
SW-SG350-08#
Solved! Go to Solution.
04-06-2022 07:21 AM
hi
very dificult to identify and I dont discard the possibility of a Bug. I´d upgrade the switch, at least one of them, just to make sure.
But, if you realy want to dig on it, I recommend you to use Wireshark to see the packet going back and forth just to identify it the loss is lack or response or if the sw is not receiving the packet.
04-06-2022 07:21 AM
hi
04-06-2022 08:06 AM
Hi Miranda,
Thanks for the reply.
I have fixed the issue. It was due to the unexpected behavior of the TP-Link Wifi controller.
