Packet loss while ping from directly connected switch
mahesh18
Level 6
Level 6
Server is directly connected to switch over etherchannel  bundle.
Both switch and server  are auto negotiaing over 100 full full.
Switch and server are capable og 1000 and they have fibre connection.
We can not hardcore settings without change control .
When i ping server with 100 packets i see 3 to 4 % packet loss.
When i ping from my pc which is in different subnet then  there is no packet loss.
I also try to ping the other servers in same subnet and they have no packet loss.
Need to know if this points to any layer 1 issue or not?
Mahesh
7 Replies 7
Kyle McKay
You are pinging the server FROM the management interface of the switch? Or is this from an IP address in the same subnet as the server such as the default gateway?
Hi Kyle,
Very good question.
I ssh  on to switch management IP which is also my pcs default gateway.
My pc and server are in different subnet.
Mahesh
devils_advocate
Level 7
Level 7
Can you run the following show commands on the server interface and post back the results?
#show run interface...
#show interface....
Here is info
sh run int port-channel 12
Building configuration...
Current configuration : 118 bytes
interface Port-channel12
switchport
switchport access vlan 500
switchport mode access
end
sh etherchannel summary
12     Po12(SU)         -        Gi4/8(P)    Gi4/11(P)
sh run int gigabitEthernet 4/8
Current configuration : 160 bytes
interface GigabitEthernet4/8
channel-group 12 mode on
spanning-tree portfast
end
sh run int gigabitEthernet 4/11
Current configuration : 161 bytes
interface GigabitEthernet4/11
end
sh int gigabitEthernet 4/8
GigabitEthernet4/8 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet Port, address is 000d.2883.a327 (bia 000d.2883.a327)
   MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 7/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, link type is auto, media type is 10/100/1000-TX
  input flow-control is on, output flow-control is on
  Last input never, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 4925
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 416000 bits/sec, 57 packets/sec
  5 minute output rate 2918000 bits/sec, 2676 packets/sec
     750628198 packets input, 532160444426 bytes, 0 no buffer
     Received 102977 broadcasts (5 multicasts)
     17732078983 packets output, 2305698693584 bytes, 0 underruns
     0 lost carrier, 0 no carrier
sh int gigabitEthernet 4/11
GigabitEthernet4/11 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet Port, address is 000d.2883.a32a (bia 000d.2883.a32a)
     reliability 255/255, txload 3/255, rxload 177/255
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 69772000 bits/sec, 6324 packets/sec
  5 minute output rate 1223000 bits/sec, 180 packets/sec
     40932682008 packets input, 55884935774434 bytes, 0 no buffer
     Received 20 broadcasts (6 multicasts)
     5202320061 packets output, 2041048473088 bytes, 0 underruns
As you can see there are no errors on the server ports.
Mahesh
Rasika Nayanajith
is there any control plane policing enable on your switch ?
There is no class map and policy map configured.
I have seen issues such as this a few times on Management SVI interfaces of network switches and I do not believe it is anything worth worrying about. However if it is something concerning you, it may be advisable to contact TAC.
