Packet size on TX ring/Rx ring
sarahr202
Level 5
Level 5
Hi everybody,
I have started studying QOS a little deeper now:)
R1#show controllers ethernet 1/0
ADDR: 649B9654, FASTSEND: 6005A794, MCI_INDEX: 0
Omitted!!
rx ring entries=32, tx ring entries=64
Above we see RX ring can hold up to 32 packets and TX ring can hold up to 64.  But what is maximum packet size ? Does RX 32 means it can hold 32 packets of 64 bytes or 1500 bytes?
Does this size  factor in layer 2 overhead for example a normal untagged Ethernet II may add up to 18 bytes to IP packet so 64 byte packet  will be  82 bytes.
acampbell
Hi Sarah,
May be have a read at these 2 links.
This one is quite old but still applies today.
1) http://www.cisco.com/c/en/us/support/docs/asynchronous-transfer-mode-atm/ip-to-atm-class-of-service/6142-txringlimit-6142.html
Then
2) http://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/quality-of-service-qos/sol_ov_c22-708224.html
Alex
Regards, Alex. Please rate useful posts.
acampbell
Hi Sarah,
Then
Alex
Good links, thanks Alex,
Actually already read the first one before I posted my question, but it did not say anything the packet size on TX ring.  But based on the link, I feel it works the same way it does for ATM interface.
I.e MTU of interface and layer 2 encapsulation being used on the interface will determine the packet size being referred to TX ring entries 64 .
