Showing results forĀ
Search instead forĀ
Did you mean:Ā
packet tracer and 2950
eng_karim
after enabling router  ports and before any config why I get connectivity on link R---SW2960 and no connectivity on link R --- SW2950
and the port is enabled on SW 2950
but I get this line on show command
Switch#show int fa 0/1
FastEthernet0/1 is down, line protocol is down (disabled)
Kevin Dorrell
Level 10
Level 10
... or it could be that you are using crossed cables.  Between a router and a switch, you should use a straight cable.  The 2960 has auto-crossover detection, but the 2950 does not, so the 2960 can compensate for having the wrong type of cable.
Kevin Dorrell
Luxembourg
glen.grant
   One end or the other is not turned up   or a  bug in the program.  If it lets you post configs maybe you can post here.
Kevin Dorrell
Level 10
Level 10
Kevin Dorrell
Luxembourg
