Packet Tracer - Cant Edit Interface on Router
Hi, I'm new to PT and trying to follow a tutorial on how to assign an IP to a router interface. For some reason, when i try to enter the port number to try and do this, i'm just thrown back into enable mode rather than conf-if mode. Is there something I'm doing wrong here. Below shows my process.
Router>enable
Router#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#interface gigabitEthernet 0/0/0
Router#
%SYS-5-CONFIG_I: Configured from console by console
Any help is much appreciated!
Sean
5 Replies 5
luis_cordova
Hi @seansmith08964998
Maybe it is a PT bug.
What router are you using?
With this info I will check on my PC.
It's an extremely basic setup. Its just a 4321 Router connected to a 3650 Multilayer switch. I've attached a screenshot to illustrate the setup.
I thought it may also be a bug. I've tried re-starting PT and using different routers and switches, however I still have the same issue.
Thanks for your help
it works in version 7.3.0. Try and 'no shut' the interface first, before assigning the IP address...
Thats the issue though, If i try to access the interface to execute a no shutdown command or assign an ip, I am kicked out to enable mode. I've attached a screenshot of the issue
It must be a PT bug.
I suggest you uninstall the program and reinstall it.
I have recreated the topology and it works for me.
