Help on Alert Analysis: cisco Nexus 3132QV
ciscomdsmagic
Experts;
We have two cisco Nexus 3132QV's, periodically sent us alerts via email as following. I would appreciate it if someone can help to point out if there are any issues or just a regular informational? Thank you!
Severity Level:2
Series:Nexus9000
Switch Priority:0
Device Id:N3K-C3132Q-V@C@FOC2217R14G
Server Id:N3K-C3132Q-V@C@FOC2217R14G
Time of Event:2020-04-11 00:53:25 GMT+00:00 Message Name:full Message Type:inventory System Name:abc-sw-04 Contact Name:send.abc.corp Contact Email:abc-company
Affected Chassis Serial Number:FOC2217R14G Affected Chassis Hardware Version:1.0 Affected Chassis Software Version:7.0(3)I4(1) Affected Chassis Part No:68-5879-01 end chassis information:
start attachment
type:text
data:
Mod Ports Module-Type Model Status
1 32 32x40G Supervisor N3K-C3132Q-V active *
Mod Sw Hw Slot
1 7.0(3)I4(1) 1.0 NA
Mod MAC-Address(es) Serial-Num
1 28-ac-9e-29-17-c8 to 28-ac-9e-29-18-2f FOC221614YN
Mod Online Diag Status
1 Pass
* this terminal session
end attachment
start attachment
type:text
data:
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (C) 2002-2016, Cisco and/or its affiliates.
All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under their own
licenses, such as open source. This software is provided "as is," and unless
otherwise stated, there is no warranty, express or implied, including but not
limited to warranties of merchantability and fitness for a particular purpose.
Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or
GNU General Public License (GPL) version 3.0 or the GNU
Lesser General Public License (LGPL) Version 2.1 or
Lesser General Public License (LGPL) Version 2.0.
A copy of each such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://opensource.org/licenses/gpl-3.0.html and
http://www.opensource.org/licenses/lgpl-2.1.php and
http://www.gnu.org/licenses/old-licenses/library.txt.
Software
BIOS: version 04.24
NXOS: version 7.0(3)I4(1)
BIOS compile time: 04/21/2016
NXOS image file is: bootflash:///nxos.7.0.3.I4.1.bin
NXOS compile time: 5/15/2016 20:00:00 [05/16/2016 03:24:30]
Hardware
cisco Nexus 3132QV Chassis
Intel(R) Core(TM) i3- CPU @ 2.50GHz with 16401852 kB of memory.
Processor Board ID FOC221614YN
Device name: abc-sw-04
bootflash: 15137792 kB
usb1: 0 kB (expansion flash)
Kernel uptime is 546 day(s), 0 hour(s), 11 minute(s), 36 second(s)
Last reset at 789328 usecs after Sat Oct 13 00:39:19 2018
Reason: Reset due to upgrade
System version: 7.0(3)I7(4)
Service:
plugin
Core Plugin, Ethernet Plugin
Active Package(s):
end attachment
start attachment
type:text
data:
Software
BIOS: version 04.24
Hardware
Kernel uptime is 546 day(s), 0 hour(s), 11 minute(s), 35 second(s)
Last reset at 789328 usecs after 1539391159
Service:
plugin
Switch hardware ID information
Switch is booted up
Switch type is : Nexus 3132QV Chassis
Model number is N3K-C3132Q-V
H/W version is 1.0
Part Number is 68-5879-01
Part Revision is E1
Manufacture Date is Year 2018 Week 17
Serial number is FOC2217R14G
CLEI code is CMMTY10BRA
Chassis has 0 Module slots
Module1 ok
Module type is : 32x40G Supervisor
0 submodules are present
H/W version is 1.0
Part Number is 73-17843-01
Part Revision is E0
Manufacture Date is Year 2018 Week 16
Serial number is FOC221614YN
Chassis has 2 PowerSupply Slots
PS1 ok
Power supply type is: 7005.60W 220v AC
Model number is N2200-PAC-400W
H/W version is 1280.0
Part Number is 341-0375-08
Part Revision is A1
Serial number is LIT22174DJ2
CLEI code is COUPAHGBAA
PS2 ok
Part Revision is A1
Serial number is LIT2217322A
Chassis has 4 Fan slots
Fan1 ok
Fan2 ok
Fan3 ok
Fan4 ok
end attachment
start attachment
name:show inventory
type:text
data:
NAME: "Chassis", DESCR: "Nexus 3132QV Chassis"
PID: N3K-C3132Q-V , VID: V01 , SN: FOC2217R14G
NAME: "Slot 1", DESCR: "32x40G Supervisor"
PID: N3K-C3132Q-V , VID: V01 , SN: FOC221614YN
NAME: "Power Supply 1", DESCR: "Nexus 3132QV Chassis Power Supply"
PID: N2200-PAC-400W , VID: V06 , SN: LIT22174DJ2
NAME: "Power Supply 2", DESCR: "Nexus 3132QV Chassis Power Supply"
PID: N2200-PAC-400W , VID: V06 , SN: LIT2217322A
NAME: "Fan 1", DESCR: "Nexus 3132QV Chassis Fan Module"
PID: NXA-FAN-30CFM , VID: V00 , SN: N/A
NAME: "Fan 2", DESCR: "Nexus 3132QV Chassis Fan Module"
NAME: "Fan 3", DESCR: "Nexus 3132QV Chassis Fan Module"
NAME: "Fan 4", DESCR: "Nexus 3132QV Chassis Fan Module"
end attachment
start attachment
name:show system uptime
type:text
data:
System start time: Sat Oct 13 00:43:14 2018
System uptime: 546 days, 0 hours, 9 minutes, 50 seconds
Kernel uptime: 546 days, 0 hours, 11 minutes, 34 seconds
end attachment
start attachment
name:show sprom all
type:text
data:
DISPLAY active supervisor sprom contents:
Common block:
Block Signature : 0xABAB
Block Version : 3
Block Length : 160
Block Checksum : 0x17CC
EEPROM Size : 65535
Block Count : 3
FRU Major Type : 0x6002
FRU Minor Type : 0x0
OEM String : Cisco Systems, Inc.
Product Number : N3K-C3132Q-V
Serial Number : FOC221614YN
Part Number : 73-17843-01
Part Revision : E0
Mfg Deviation : 0
H/W Version : 1.0
Mfg Bits : 0
Engineer Use : 0
snmpOID : 9.12.3.1.9.85.28.0
Power Consump : 2916
RMA Code : 0-0-0-0
CLEI Code : CMMTY10BRA
VID : V01
Supervisor Module specific block:
Block Signature : 0x6002
Block Version : 2
Block Length : 103
Block Checksum : 0x6E7
Feature Bits : 0x0
HW Changes Bits : 0x1
Card Index : 11120
MAC Addresses : 00-00-00-00-00-00
Number of MACs : 0
Number of EPLD : 0
Port Type-Num : 1-96;2-8
Sensor #1 : 101,95
Sensor #2 : 62,56
Sensor #3 : 52,44
Sensor #4 : 48,42
Sensor #5 : 101,95
Sensor #6 : 60,53
Sensor #7 : 54,46
Sensor #8 : 57,50
Max Connector Power: 4000
Cooling Requirement: 65
Ambient Temperature: 45
Temperature Sensor block:
Block Signature : 0x6008
Block Version : 1
Block Length : 71
Block Checksum : 0x8B1
Number of Valid Sensors : 1
Sensor #9 : -128,-128
Sensor #10 : -128,-128
Sensor #11 : -128,-128
Sensor #12 : -128,-128
Sensor #13 : -128,-128
Sensor #14 : -128,-128
Sensor #15 : -128,-128
Sensor #16 : -128,-128
Sensor #17 : 0,0
Sensor #18 : 0,0
Sensor #19 : 0,0
Sensor #20 : 0,0
Sensor #21 : 0,0
Sensor #22 : 0,0
Sensor #23 : 0,0
Sensor #24 : 0,0
Sensor #25 : 0,0
Sensor #26 : 0,0
Sensor #27 : 0,0
Sensor #28 : 0,0
Sensor #29 : 0,0
Sensor #30 : 0,0
Sensor #31 : 0,0
Sensor #32 : 0,0
Sensor #33 : 0,0
Sensor #34 : 0,0
Sensor #35 : 0,0
Sensor #36 : 0,0
Sensor #37 : 0,0
Sensor #38 : 0,0
Sensor #39 : 0,0
Sensor #40 : 0,0
DISPLAY backplane sprom 1 contents:
Common block:
Block Version : 3
Block Length : 160
Block Checksum : 0x1765
EEPROM Size : 65535
Block Count : 5
FRU Major Type : 0x6001
Serial Number : FOC2217R14G
Part Number : 68-5879-01
Part Revision : E1
Mfg Deviation : 0
H/W Version : 1.0
Mfg Bits : 0
Engineer Use : 0
snmpOID : 9.12.3.1.4.30.0.0
Power Consump : 0
RMA Code : 0-0-0-0
VID : V01
Chassis specific block:
Block Signature : 0x6001
Block Version : 3
Block Length : 39
Block Checksum : 0x3BE
Feature Bits : 0x0
Stackmib OID : 0
MAC Addresses : 28-ac-9e-29-17-c0
Number of MACs : 192
OEM Enterprise : 0
OEM MIB Offset : 0
MAX Connector Power: 0
WWN software-module specific block:
Block Signature : 0x6005
Block Version : 1
Block Length : 0
Block Checksum : 0x66
wwn usage bits:
00 00 00 00 00 00 00 00
00 00
License software-module specific block:
Block Signature : 0x6006
Block Version : 1
Block Length : 16
Block Checksum : 0x77
lic usage bits:
Second Serial number specific block:
Block Signature : 0x6007
Block Version : 1
Block Length : 28
Block Checksum : 0x84
Serial Number :
DISPLAY power-supply:1 sprom contents:
Common block:
Block Version : 3
Block Length : 160
Block Checksum : 0x5E18
EEPROM Size : 65535
Block Count : 512
FRU Major Type : 0x1AB
Product Number : N2200-PAC-400W
Serial Number : LIT22174DJ2
Part Number : 341-0375-08
Part Revision : A1
Mfg Deviation :
H/W Version : 1280.0
Mfg Bits : 0
Engineer Use : 0
snmpOID : 2304.3072.768.256.1536.4353.0.0
Power Consump : -7156
RMA Code : 0-0-0-0
CLEI Code : COUPAHGBAA
VID : V06
Power supply specific block:
Block Signature : 0x1AB
Block Version : 2
Block Length : 36
Block Checksum : 0xB202
Feature Bits : 0x0
Current 110v : 58380
Current 220v : 58380
Stackmib OID : 0
DISPLAY power-supply:2 sprom contents:
Common block:
Block Version : 3
Block Length : 160
Block Checksum : 0x4218
EEPROM Size : 65535
Block Count : 512
Serial Number : LIT2217322A
Part Revision : A1
Mfg Deviation :
Mfg Bits : 0
Engineer Use : 0
RMA Code : 0-0-0-0
VID : V06
Block Version : 2
Block Length : 36
Feature Bits : 0x0
Stackmib OID : 0
end attachment
start attachment
name:show license usage
type:text
data:
Feature Ins Lic Status Expiry Date Comments
Count
16P_UPG_PKG No - Unused -
32P_LIC_PKG No - Unused -
24P_N3K_LIC_PKG No - Unused -
48P_N3K_UPG_PKG No - Unused -
LAN_BASE_SERVICES_PKG No - Unused -
LAN_ENTERPRISE_SERVICES_PKG No - Unused -
end attachment
start attachment
name:show vdc current-vdc
type:text
data:
Current vdc is 1 - abc-sw-04
end attachment
start attachment
name:show vdc membership
type:text
data:
vdc_id: 0 vdc_name: Unallocated interfaces:
vdc_id: 1 vdc_name: abc-sw-04 interfaces:
Ethernet1/1 Ethernet1/2 Ethernet1/3
Ethernet1/4 Ethernet1/5 Ethernet1/6
Ethernet1/7 Ethernet1/8 Ethernet1/9
Ethernet1/10 Ethernet1/11 Ethernet1/12
Ethernet1/13 Ethernet1/14 Ethernet1/15
Ethernet1/16 Ethernet1/17 Ethernet1/18
Ethernet1/19 Ethernet1/20 Ethernet1/21
Ethernet1/22 Ethernet1/23 Ethernet1/24
Ethernet1/25 Ethernet1/26 Ethernet1/27
Ethernet1/28 Ethernet1/29 Ethernet1/30
Ethernet1/31 Ethernet1/32 Ethernet1/1/1
Ethernet1/1/2 Ethernet1/1/3 Ethernet1/1/4
Ethernet1/2/1 Ethernet1/2/2 Ethernet1/2/3
Ethernet1/2/4 Ethernet1/3/1 Ethernet1/3/2
Ethernet1/3/3 Ethernet1/3/4 Ethernet1/4/1
Ethernet1/4/2 Ethernet1/4/3 Ethernet1/4/4
Ethernet1/5/1 Ethernet1/5/2 Ethernet1/5/3
Ethernet1/5/4 Ethernet1/6/1 Ethernet1/6/2
Ethernet1/6/3 Ethernet1/6/4
end attachment
Reza Sharifi
Not sure what type software you use for managing your devices, but this seems to be an informational snapshot alert for the whole switch including sh ver, sh interface, sh module, etc.. There maybe a way to disable the alert from the management software.
With such length of messages in it, I am not sure if there are any indicating anything not right.
Two such switches are used for inter-communication between two NetApp filers. There are no any other software managing them but OS on the switch.
I don't necessarily wanted to disable them.
Thanks for your input.
Sergiu.Daniluk
Seems like the logs from the callhome email are pointing out to PSU and temperature. Maybe you can check the logs directly on the switch, and see if anything is generated during the time you received the email.
show logging log
show environment temperature
Btw, Nexus is a data center switch. It will be more helpful for you to direct queries about Nexus switches in the Data Center technology community.
Sergiu
