Packet Tracer Cisco ASA 5505 - Unable to enter same-secuirty-traffic permit intra-interface command
Ivan91
Hi All,
I'm unable to enter this command for some reason. Does anyone know if it is not supported in packet tracer...I could have swore I had entered it before.
johnlloyd_13
Level 9
Level 9
hi,
you'll see if the command is supported by using the syntax help (using the ?)
did you enter the command in global config mode?
what error do you get?
Contrary to my recollection, the command is not supported in packet tracer.
Thanks for the response, John.
