Packet tracer help - Laptop DHCP failure
mhollstein4
I am needing help with the laptops that are wireless IP Configuration, the DHCP keeps failing.
I have also attached the packet tracer zip file to see if anyone can offer some advice on what I need to do/change the PCs are successful but the laptops are where I am running into the issue.
Thank you
@mhollstein4
 Check the file I am attaching. Laptops must be getting IP address from DHCP now.
marce1000
    -  FYI Community group for Packet Tracer project questions
  M.
@mhollstein4
