Packet Tracer, Help me
Koppen
I need help with my PKT..
I should be able to reach R4--ISP from PC5.. But it doesnt work.
Can someone see where my problem is? Because i cant get this to work..
Password is dt153g & L2.
Thank you!
here is the project with the GW router configured with subinterfaces and NAT connectivity.
11 Replies 11
what are the requirements ? With multiple routers and redundant paths, it is almost impossible to reach full connectivity with static routes.
I would suggest to use EIGRP, and configure this on all L3 devices (the L3 switch and all routers). Delete all static routes as well:
router eigrp 1
network 0.0.0.0
no auto-summary
Hello!
Thank you for your answer,really!
Regarding requirements, RIPv2 is one of them..
Should I delete all off my static routes anyway?
I have connection in my LAN and in my WAN but my Gw-router wont route between them...Im pretty lost
I see. The problem is that you have configured subinterfaces on the GW router, these keep the networks from the L3 switch from being installed in the routing table. I have removed these subinterfaces, find attached the revised file with full connectivity. I have saved the file in Packet Tracer version 7.3.1., make sure you run the same version.
Hi again Georg. The router GW should be configured as a router on a stick. Is it not necessary to have the subinterfaces then on GW? Also, the NAT does not seem to work, i can't find the translations in GW when i run the command: show ip nat translations. Any ideas of how to resolve this?
Thank you!
if the GW router is supposed to have subinterface, the S1 switch needs to be a layer 3 switch.
By the way, the user in the thread below is working on the exact same network...
https://community.cisco.com/t5/switching/packet-tracer-nat-help/m-p/4258045
Hello!
Oh I thought I was alone on this terrible task..haha.
Okey, so my switch S1 is not a layer 3 switch? I thought so!
Thank you!
The biggest of thanks to you Georg!
Have a great day!
the other user with an identical network wanted to use Vlans on S1, and have S1 function as a layer 3 switch. I guess if it is not clearly specified, you could use both.
Hmm, yes I can see that. In the best scenario i should use a router-on-a-stick setup.. But I think I can slip that part and be pretty happy with this.
Or is it poosible with my setup?
either way is fine, it doesn't matter for connectivity.
