Packet Tracer Help. What am I Missing. New to Packet Tracer
Malgandalf01
I am new to PT and taking the online intro course.
One of the designs they are using at the beginning has three computers connected to a WRT300N which connects to the internet via a cable modem the the cloud then to a server.
I cannot for the life of me get the WRT300n to receive an ip address in the internet port so I cannot ping or get DNS from a workstation to the remote server.
. What silly little thing am I missing?
Yes I am currently a complete noob with PT.
TIA - Mike
45 Replies 45
Thanks for your help
I join my packet tracer file
The internet of WiFi Router has not ip (dhcp) !
where is the file ?
? I still do not see an attachment...
I have opened the file. but all devices get a valid DHCP address. Which one does not work in your lab ?
I can't ping the server cisco.com and the interface of wifi router to
internet don't get a dhcp IP...
below the result of the ping from PC0:
Packet Tracer PC Command Line 1.0
C:\>ping cisco.com
Pinging 208.67.220.220 with 32 bytes of data:
Reply from 208.67.220.220: bytes=32 time=29ms TTL=127
Reply from 208.67.220.220: bytes=32 time=1ms TTL=127
Ping statistics for 208.67.220.220:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 29ms, Average = 8ms
The interface you are referring to gets IP address 208.67.220.1/24 via DHCP.
Which version of Packet Tracer are you running ?
[image: image.png]
Is 7.2.1.0218
I am on Windows10 v1809
I have opened your file, saved it (I am using the exact same version as you do, on a Windows 10 machine. You need to wait for a minute for PC0 to get its IP address...
Thanks, I will try on monday je cause i améliorations travelling.
is the problem solved? Get the same here, trying to update win 10 to 1903 build right now.
what exactly is the problem ? Post your (zipped) Packet Tracer project file here...
I hope you all can forgive me for re-opening an oldish thread. But I was also having problems with setting up this scenario and getting it to work as per the Cisco instructions. Simply put, I couldn't get the communication between the wireless router and cable modem to work, despite the interfaces being green, so I was never able to ping the Cisco router from PC0.
I have downloaded and run the revised/fixed PT file which Georg kindly uploaded (see below).
I am a complete noob to Packet Tracer and there are also significant gaps in my conceptual knowledge re. networking in general, I am finding, so I am trying to rectify these gaps. Sorry, then, if these are dumb questions (!), but based on Georg's uploaded PT file, I would like to ask the following, if I may?
- If you didn't configure the Cisco server statically with the default gateway, how would it ever find the wireless router through the internet?
- Why the Cisco router cannot ping PC0? ("Request timed out")
- Why the Internet port IP address on the wireless router is what it is and why this differs from the LAN IP address of the router?
- Why a straight-thru cable between the wireless router and cable modem doesn't work (despite the scenario instructions from Cisco)
Thanks for your help!
post the zipped .pkt file here...
Thanks, Georg - here it is...
