Packet tracer, NAT help.
Vattenglas
Hi all,
I have a problem that i'm hoping someone can help me out with. I'm new to this forum so maybe this isn't the right forum for my post.
I'm trying to configure dynamic NAT on a cisco 2811 router. The set up should be the following: 64.0.0.0/8 network as the local addresses that should be translated to 32.0.0.0/29 network which is the public network. The public network has 32.0.0.2 - 32.0.0.6 addresses to be used for translation.
I want all possible local addresses from 64.0.0.0 to be eligible for translation.
How can i accomplish this in packet tracer? Any help is super useful, thanks!
Attached is the current config, which isn't working. I can send the packet tracer file if anyone is interested in helping out.
Thanks a bunch!
for some weird reason, all the changes I made seem to have disappeared from the file that I sent you. Probably my fault...
I am sending the revised file again, just in case, also the full configs of the L3 switch and the 5 routers.
The only thing I did not get to work was the NAT pool. Not sure why that does not work, it could be a flaw in (this version of) Packet Tracer. Normally, this would work:
ip nat pool NAT 32.0.0.2 32.0.0.6 netmask 255.255.255.248
ip nat inside source list 1 pool NAT overload
As soon as I use this, all communications from S1 stops. Normal NAT works fine:
ip nat inside source list 1 interface FastEthernet0/0 overload
Either way, here are the configs and the (hopefully working) PT project file:
S1#sh run
Building configuration...
Current configuration : 2388 bytes
version 12.2(37)SE1
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname S1
enable secret 5 $1$mERr$IvYW/UrXhN.ooY/0oyLN/.
ip routing
spanning-tree mode pvst
interface FastEthernet0/1
switchport mode access
switchport nonegotiate
interface FastEthernet0/2
interface FastEthernet0/3
switchport trunk native vlan 3
switchport mode trunk
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 64.0.0.2 255.248.0.0
interface Vlan40
mac-address 00e0.f928.5d01
ip address 64.40.0.1 255.255.255.248
interface Vlan48
mac-address 00e0.f928.5d02
ip address 64.48.0.1 255.255.255.248
interface Vlan56
mac-address 00e0.f928.5d03
ip address 64.56.0.1 255.255.255.248
interface Vlan64
mac-address 00e0.f928.5d04
ip address 64.64.0.1 255.255.255.248
interface Vlan72
mac-address 00e0.f928.5d05
ip address 64.72.0.1 255.255.255.248
interface Vlan80
mac-address 00e0.f928.5d06
ip address 64.80.0.1 255.255.255.248
interface Vlan88
mac-address 00e0.f928.5d07
ip address 64.88.0.1 255.255.255.248
interface Vlan96
mac-address 00e0.f928.5d08
ip address 64.96.0.1 255.255.255.248
router rip
version 2
network 64.0.0.0
ip classless
ip flow-export version 9
banner motd ^CUnauthorized access to this device is prohibited!^C
line con 0
password 7 0825581F5C4A02
logging synchronous
login
line aux 0
line vty 0 4
logging synchronous
login
end
R0#sh run
Current configuration : 942 bytes
version 12.4
hostname R0
ip cef
no ipv6 cef
ip address 32.0.0.1 255.255.255.248
ip nat outside
duplex auto
speed auto
ip address 64.0.0.1 255.248.0.0
ip nat inside
duplex auto
speed auto
interface Vlan1
no ip address
router rip
version 2
network 32.0.0.0
network 64.0.0.0
ip classless
access-list 1 permit 64.0.0.0 0.255.255.255
banner motd ^CUnauthorized access to this device is prohibited^C
line con 0
logging synchronous
login
line aux 0
line vty 0 4
logging synchronous
login
end
R1#sh run
Current configuration : 911 bytes
version 12.4
hostname R1
ip cef
no ipv6 cef
ip address 32.0.0.2 255.255.255.248
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
ip address 1.2.2.1 255.255.255.252
interface Serial0/0/1
ip address 1.2.2.5 255.255.255.252
interface Vlan1
no ip address
shutdown
router rip
version 2
network 1.0.0.0
network 32.0.0.0
ip classless
line con 0
login
line aux 0
line vty 0 4
no login
line vty 5 15
no login
end
R2#sh run
Current configuration : 934 bytes
version 12.4
hostname R2
ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
ip address 1.2.2.2 255.255.255.252
clock rate 250000
ip address 1.2.2.13 255.255.255.252
clock rate 2000000
interface Vlan1
no ip address
shutdown
router rip
version 2
network 1.0.0.0
ip classless
no cdp run
line con 0
login
line aux 0
line vty 0 4
no login
line vty 5 15
no login
end
R3#sh run
Current configuration : 913 bytes
version 12.4
hostname R3
ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
ip address 1.2.2.6 255.255.255.252
clock rate 250000
ip address 1.2.2.9 255.255.255.252
interface Vlan1
no ip address
shutdown
router rip
version 2
network 1.0.0.0
ip classless
no cdp run
line con 0
login
line aux 0
line vty 0 4
no login
line vty 5 15
no login
end
R4#sh run
Current configuration : 1026 bytes
version 12.4
hostname R4
ip cef
no ipv6 cef
interface Loopback0
ip address 209.78.74.59 255.255.255.0
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
ip address 1.2.2.14 255.255.255.252
clock rate 250000
shutdown
ip address 1.2.2.10 255.255.255.252
clock rate 128000
interface Vlan1
no ip address
shutdown
router rip
version 2
network 1.0.0.0
network 209.78.74.0
ip classless
no cdp run
line con 0
login
line aux 0
line vty 0 4
no login
line vty 5 15
no login
end
Vattenglas
basically, the below is what you need to add to the configuration of your Router0:
I have attached the revised file...
Thanks!
The running configuration isn't working quite as intended yet. How can i make sure that all of the routers are advertising the 32.0.0.0 network?
S1#sh run
version 12.2(37)SE1
hostname S1
ip routing
interface Vlan1
interface Vlan40
interface Vlan48
interface Vlan56
interface Vlan64
interface Vlan72
interface Vlan80
interface Vlan88
interface Vlan96
router rip
version 2
network 64.0.0.0
ip classless
line con 0
logging synchronous
login
line aux 0
line vty 0 4
logging synchronous
login
end
R0#sh run
version 12.4
hostname R0
ip cef
no ipv6 cef
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
interface Vlan1
no ip address
router rip
version 2
network 32.0.0.0
network 64.0.0.0
ip classless
line con 0
logging synchronous
login
line aux 0
line vty 0 4
logging synchronous
login
end
R1#sh run
version 12.4
hostname R1
ip cef
no ipv6 cef
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router rip
version 2
network 1.0.0.0
network 32.0.0.0
ip classless
line con 0
login
line aux 0
line vty 0 4
no login
line vty 5 15
no login
end
R2#sh run
version 12.4
hostname R2
ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
clock rate 250000
clock rate 2000000
interface Vlan1
no ip address
shutdown
router rip
version 2
network 1.0.0.0
ip classless
no cdp run
line con 0
login
line aux 0
line vty 0 4
no login
line vty 5 15
no login
end
R3#sh run
version 12.4
hostname R3
ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
clock rate 250000
interface Vlan1
no ip address
shutdown
router rip
version 2
network 1.0.0.0
ip classless
no cdp run
line con 0
login
line aux 0
line vty 0 4
no login
line vty 5 15
no login
end
R4#sh run
version 12.4
hostname R4
ip cef
no ipv6 cef
interface Loopback0
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
clock rate 250000
shutdown
clock rate 128000
interface Vlan1
no ip address
shutdown
router rip
version 2
network 1.0.0.0
network 209.78.74.0
ip classless
no cdp run
line con 0
login
line aux 0
line vty 0 4
no login
line vty 5 15
no login
end
