Packet tracer OSPF issue
thajiyev9
Hello!
I have an issue about OSPF in packet tracer. I upload my topology. There are 5 router in my network and R4 connected to R5(ISP). So that, I have default route to isp and originate it in ospf. R2 get this default route with 2 different way.  When i ping from R1 to R5, if R2 using route via 10.10.12.0, it cause problem. I dont want default route via 10.10.12.1, only want to use 10.10.24.4. Changing bandwith and ospf cost didnt change anything.
Edit:
English is not my mother tongue, so I apologize for writing mistakes.
4 Accepted Solutions
Julio E. Moisa
Please correct me if Im understanding wrong but you want to prefer the path from R1 through R3 instead R2?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
the problem is that Packet Tracer does not really simulate 'real' IOS devices, but rather executes a number of commands and displays pre-programmed results.
If you lab this is e.g. GNS3, your router R4 would not even generate a default route (to R2 and R3) because there is no default route existing in the routing table. You would need to add the 'always' keyword to the 'default-information originate' command for the default route to be installed regardless of its existence in the routing table. Also, having to paths is not happening in a real network. I don't know why Packet Tracer installs both default routes.
Conclusion: forget about it and lab this in GNS3 to get more reliable results.
It looks like a bug on the PT, if you verify the routing table on R2 it shows the same metrics for both default routes and from R1's perspective it learns one of the 2 paths until you execute: show ip ospf process <yes>.
I changed the area number to zero and it fixed the trouble, probably it is related with multi-areas on packet tracer.
You are welcome :-)
Yes it could be a bug on PT.
Have a great new year.
25 Replies 25
Julio E. Moisa
Yeah, it is true.
It can depend of the cost, try configuring the following cost under the link between R1 and R2:
ip ospf cost 20000
And try in few seconds again. The trafic should go through: R1 ---> R3 ---> R4 ---> R5
Sorry, but it did not change anything. Both of them are in routing table.
Ok
Have you verified if the path is being known through R3? You can shutdown the R1's interface facing to R2 and try again.
I shutdown R1, gig0/0 interface and default route via 10.10.12.0 disappear.
Ok, are you able to go through R3, R4 and R5?
Before i shutdown R1's interface facing to R2 the same issue happened in R3 ( via 10.10.13.1 ) but when i shutdown interface, 10.10.13.1 disappear and all ping were success. Then i up interface and the same issue appeared.
Could you please share the configuration of each router? it could be paste here or attaching a notepad.
Thank you in advance.
May i send you my pkt file?
Yes but I think that file cannot be attached. Please let me share a configuration based on your topology.
R1
conf t
int fa0/0
description TO-R2
ip add 10.0.12.1 255.255.255.0
no shutdown
int fa0/1
description TO-R3
ip add 10.0.13.1 255.255.255.0
no shutdown
router ospf 1
net 10.0.12.1 0.0.0.0 area 0
net 10.0.13.1 0.0.0.0 area 0
R2
conf t
int fa0/0
description TO-R1
ip add 10.0.12.2 255.255.255.0
no shutdown
int fa0/1
description TO-R4
ip add 10.0.24.2 255.255.255.0
no shutdown
router ospf 1
net 10.0.12.2 0.0.0.0 area 0
net 10.0.24.2 0.0.0.0 area 0
R3
conf t
int fa0/0
description TO-R1
ip add 10.0.13.3 255.255.255.0
no shutdown
int fa0/1
description TO-R4
ip add 10.0.34.3 255.255.255.0
no shutdown
router ospf 1
net 10.0.13.3 0.0.0.0 area 0
net 10.0.34.3 0.0.0.0 area 0
R4
conf t
int fa0/0
description TO-R2
ip add 10.0.24.4 255.255.255.0
no shutdown
int fa0/1
description TO-R3
ip add 10.0.34.4  255.255.255.0
no shutdown
int fa0/2
description TO-R5
ip add 10.0.45.4  255.255.255.0
no shutdown
router ospf 1
net 10.0.34.4  0.0.0.0 area 0
net 10.0.24.4  0.0.0.0 area 0
net 10.0.45.4  0.0.0.0 area 0
R5
interface loopback 0
ip add 5.5.5.5 255.255.255.255
conf t
int fa0/0
description TO-R4
ip add 10.0.45.5 255.255.255.0
no shutdown
router ospf 1
net 10.0.45.5 0.0.0.0 area 0
net 5.5.5.5 0.0.0.0 area 0
You should have something like that configuration, R1 will have 2 equal cost path to R5's loopback. You could configure higher cost between R1 and R2 to move the traffic to R3.
R5  dont use ospf. I design as R5 is ISP and R4 have static route to R5. Then i originate this static route with ospf.
R4
ip route 0.0.0.0 0.0.0.0 10.10.45.5
(router mode)
R1
conf t
int fa0/0
ip add 10.10.12.1 255.255.255.0
no shutdown
int fa0/2
ip add 10.10.13.1 255.255.255.0
no shutdown
cost 100
router ospf 1
net 10.10.12.1 0.0.0.0 area 0
net 10.10.13.1 0.0.0.0 area 0
R2
conf t
int fa0/0
ip add 10.10.12.2 255.255.255.0
no shutdown
int fa0/1
ip add 10.10.24.2 255.255.255.0
no shutdown
router ospf 1
net 10.10.12.2 0.0.0.0 area 0
net 10.10.24.2 0.0.0.0 area 1
R3
conf t
int fa0/2
ip add 10.10.13.3 255.255.255.0
no shutdown
int fa0/1
ip add 10.10.34.3 255.255.255.0
no shutdown
router ospf 1
net 10.10.13.3 0.0.0.0 area 0
net 10.10.34.3 0.0.0.0 area 1
R4
conf t
int fa0/0
ip add 10.10.24.4 255.255.255.0
no shutdown
int fa0/1
ip add 10.10.34.4 255.255.255.0
no shutdown
int fa0/2
ip add 10.10.45.4 255.255.255.0
no shutdown
router ospf 1
net 10.10.34.4 0.0.0.0 area 1
net 10.10.24.4 0.0.0.0 area 1
passive-interface gig 0/2(faced to R5)
R5
conf t
int fa0/0
ip add 10.10.45.5 255.255.255.0
no shutdown
