Packet tracer OSPF issue
thajiyev9
Hello!
I have an issue about OSPF in packet tracer. I upload my topology. There are 5 router in my network and R4 connected to R5(ISP). So that, I have default route to isp and originate it in ospf. R2 get this default route with 2 different way.  When i ping from R1 to R5, if R2 using route via 10.10.12.0, it cause problem. I dont want default route via 10.10.12.1, only want to use 10.10.24.4. Changing bandwith and ospf cost didnt change anything.
Edit:
English is not my mother tongue, so I apologize for writing mistakes.
25 Replies 25
On a side note, you can save the Packet Tracer project file as a .jpg file and then post it...
the problem is that Packet Tracer does not really simulate 'real' IOS devices, but rather executes a number of commands and displays pre-programmed results.
If you lab this is e.g. GNS3, your router R4 would not even generate a default route (to R2 and R3) because there is no default route existing in the routing table. You would need to add the 'always' keyword to the 'default-information originate' command for the default route to be installed regardless of its existence in the routing table. Also, having to paths is not happening in a real network. I don't know why Packet Tracer installs both default routes.
Conclusion: forget about it and lab this in GNS3 to get more reliable results.
It looks like a bug on the PT, if you verify the routing table on R2 it shows the same metrics for both default routes and from R1's perspective it learns one of the 2 paths until you execute: show ip ospf process <yes>.
I changed the area number to zero and it fixed the trouble, probably it is related with multi-areas on packet tracer.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi!
There are so bugs in PT and probably i will use GNS3. Tomorrow i will change areas and try show commands.
Thank you for help !
Hi!
Yeah, some commands not working and bugs make problems for my work. Probaby i will start to use GNS3.
Thank you for detailed explanation
It could be, currently im creating a lab with real devices, i will keep you posted.
I would be grateful.
Definitely your configuration is ok and the trouble is with packet tracer with multi-area. I tested your same configuration on real devices and they worked as expected.
I am so happy that the problem is the packet tracer. :D Thank you for your help and explanation.
You are welcome :-)
Yes it could be a bug on PT.
Have a great new year.
