Packet Tracer running error. Any help would be great.
F12
I am trying to run Packet Tracer 7.3.0  on a Win 7 32 machine. After installation when I am trying to start PK I am receiving an error message and when I'm clicking ok I am getting to the second one. Also, if I am trying to open a .pka file I am receiving these 2 errors in a row.
I googled about this errors but I wasn't able to find a solving.
Do you have any idea about what can I do to make it start?
Thank you
21 Replies 21
PacketTracer7.exe - Imagen incorrecta
C:\Program Files\Cisco Packet Tracer 7.3.0\bin\ucrtbase.DLL no está diseñado para ejecutarse en Windows o contiene un error. Intente instalar el programa de nuevo por medio de los medios originales de instalación, o póngase en contacto con el administrador del sistema o el fabricante de software para obtener ayuda.
Aceptar
sebasgr-13
Hi!
Did you find a solution?
you have the exact same problem ?
Yeah the exact same one.
Hi!
right click on the Cisco Packet Tracer icon to open the Properties. In the 'Compatibility' tab run the compatibility troubleshooter, also, try to run the program in compatibility mode.
You also might want to run an sfc scan on your Windows machine...
https://answers.microsoft.com/en-us/windows/forum/windows_vista/dll-is-either-not-designed-to-run-on-windows-or-it/96e04287-7e81-49ab-afe5-f44449dd8322
Already did it but still the same problem.
It only happens with the 7.3 version, if i use another one it works fine.
Hello!
Thank you! i struggled with that problem since this version came out and this worked.
copiar el archivo C:\Windows\System32\ucrtbase.dll y pegarlo en  C:\Program Files\Cisco Packet Tracer 7.3.0\bin (reemplazar el archivo)
el archivo ucrtbase.dll que viene por defecto no es compatible con el que esta instalado en el sistema
Thank you so much. It really helped.
Funcionó! Muchas gracias!
Thanks spanish jesus
