Packet Tracer running error. Any help would be great.
F12
I am trying to run Packet Tracer 7.3.0  on a Win 7 32 machine. After installation when I am trying to start PK I am receiving an error message and when I'm clicking ok I am getting to the second one. Also, if I am trying to open a .pka file I am receiving these 2 errors in a row.
I googled about this errors but I wasn't able to find a solving.
Do you have any idea about what can I do to make it start?
Thank you
21 Replies 21
Gracias! en mi PC encontré el archivo dentro de esta carpeta:
C:\Program Files\Common Files\microsoft shared\ClickToRun
Funcionó perfecto.
How do you solve your problem?,I think I have the same problem but I don't understand Spanish. I would be glad if you help me.
I solved my problem thank the video
Thanks Mannn this worked for me also....
Best answer! And I don't even speak Spanish! I could understand you!
Hello, check out this video, the solution is really simple. Just in case you haven't fixed the problem. That worked for me.
https://www.youtube.com/watch?v=iR5okr_XMPs
Thanks a lot, this video works. I can open CPT now.
