packet tracer , sw with vlans wont communicate with r1
leslie.marin001
packet tracer setup . multiple vlans in both switch connections and two routers . i can not get pc1 or 2 or 3 or vlan 10,20,vlan 99 to ping outside the router. router sees the isub and everything is up and vlan 99 is trunking native to sw1 to r1 and I just cant figure it out . been two days and makes me want to quit cisco all together . I follower to the teeth router on on the stick method and it just wont allow pc to read pass
router on a stickrouter on a stick
12 Replies 12
Jon Marshall
From your attached diagram the most obvious issue is you have used the same IPs (192.168.10.1 and 192.168.20.1) on the router and the switch so you need to change that before doing anything else.
Jon
why would that create an issue between both ? router needs subinterface ( gi 0/2.10 and .20 and switch needs interface for both vlan 10 and vlan 20 ?
It's not the interfaces, it's the fact you have used the same IP addresses on two different devices.
When you ping from the PC you are not even pinging the router, you are pinging the switch by the looks of it so you will never get past the router.
If you want the PC's gateways to be on the router you need to make sure the switch IPs are not the same IP ie. just give them another IP out of the same vlans.
Jon
Just to add, both devices do not need interfaces, only the device that is doing the routing for the vlans and it is not clear from your diagram which device that is ie. the router or the switch.
Jon
oh sorry ti zipped the packet , 3 pc , 2 vlans are connected to the switch - rconnected to router r- connected to 5 other ones ( in static) . so i dont need the same ip assigned to the vlans in switch and ip address for switch has to be different to ping . would that fix the iussue where vlan 1 pc cant ping to ping to vlan 20 pc nor the routers
post the zipped Packet Tracer project (.pkt) file...
there are a lot of misconfigurations. The PCs do not have an IP address an/or default gateway, the trunk on the switch is misconfigured, the connecting router interface is misconfigured, the static routes are wrong.
I have added DHCP pools for the PCs on the left and fixed the switch and the router, you need to figure out which static routes are correct.
Attached the partly revised file.
I cannot opent he packet as it says its not compatible with this version . the pcs dont have dhcp assigned because I havent been able to ping switch and router . you said the trunking is misconfigured and the router is misconfigured . my static routes all my routers point to each other but not to the switch LAN where i'm currently having issue implementing the switch's with vlan ( i only have notes on router on a stick which might be giving me issues ) . I'll revisit the static routes , but what is misconfigured on the switch trunk and router ?
here are the configs for the switch and the router.
Switch#sh run
Building configuration...
Current configuration : 1490 bytes
version 15.0
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
spanning-tree mode pvst
interface FastEthernet0/1
switchport access vlan 10
switchport mode access
spanning-tree portfast
interface FastEthernet0/2
switchport access vlan 20
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
switchport trunk native vlan 99
switchport trunk allowed vlan 10,20
switchport mode trunk
interface Vlan1
no ip address
shutdown
interface Vlan99
ip address 192.168.99.2 255.255.255.0
ip default-gateway 192.168.99.1
line con 0
line vty 0 4
login
line vty 5 15
login
end
R1#sh run
Current configuration : 1973 bytes
version 15.1
hostname R1
ip dhcp excluded-address 192.168.10.1
ip dhcp excluded-address 192.168.20.1
ip dhcp pool VLAN10
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
ip dhcp pool VLAN20
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX152404TY-
interface GigabitEthernet0/0
description r1-con nected-r2
ip address 192.168.12.1 255.255.255.0
duplex auto
speed auto
description R1- connected --R3
ip address 192.168.13.1 255.255.255.0
duplex auto
speed auto
description trunk link to S1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/2.10
description default gateway for vlan 10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet0/2.20
description default gateway for vlan 20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
interface GigabitEthernet0/2.99
description default gateway for Vlan 99
encapsulation dot1Q 99 native
ip address 192.168.99.1 255.255.255.0
interface GigabitEthernet0/2.100
encapsulation dot1Q 100
no ip address
interface Vlan1
no ip address
ip classless
ip route 192.168.12.0 255.255.255.0 192.168.12.2
ip route 192.168.24.0 255.255.255.0 192.168.24.2
ip route 192.168.24.0 255.255.255.0 192.168.24.4
ip route 192.168.24.0 255.255.255.0 192.168.12.2
ip route 192.168.34.0 255.255.255.0 192.168.13.3
ip route 192.168.35.0 255.255.255.0 192.168.13.3
ip route 192.168.25.0 255.255.255.0 192.168.12.2
ip route 7.0.0.0 255.255.255.255 192.168.25.5
ip route 7.7.7.7 255.255.255.255 192.168.12.2
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
this process helped ping each other between vlans . but I cant still ping the router . the trunk has the ip address 192.168.99.2 , but i cant communicate between switch and router still . I have it set up that vlan 99 is trunk mode on sw g0/2  and router have vlan 99 0/2.99 has the ip address 192.168.99.1 and they still wont talk . the gi 0/2 interface itself doesnt have an ip address. and I do need the ip helper-address to send it back to the dhcp server in my packet tracer that is set up with 7.7.7.7. loopback
I don't get it to work either, with Vlan 99 being the native Vlan. This is most likely one of the flaws in Packet Tracer.
The below does work:
Switch
switchport trunk allowed vlan 10,20,99
interface Vlan1
no ip address
shutdown
interface Vlan99
Router
description default gateway for vlan 99
